[Qgis-user] plugin doesn't find exiftool executable
Alexander Bruy alexander.bruy at gmail.com
Tue Oct 4 06:07:56 PDT 2016
Hi Richard,
you should specify just directory where exiftool.exe located, not full
path to th executable file.
Hope this helps.
2016-10-04 15:42 GMT+03:00 Reginald Carlier <Reginald.Carlier at ingelmunster.be>:
> Hi Alexander,
> I installed the plugin in QGIS 2.16.3.
> When I run the ‘Import photos’ tool I point the ExifTool Config browse
> button to the exiftool(-k).exe that I have downloaded from
> http://www.sno.phy.queensu.ca/~phil/exiftool/index.html
> I installed the windows executable.
> When running the ‘Import photos’ tool it gives following error:
> Can’t locate exiftool executable! Make sure it is installed and available in
> PATH or alternatively specify path to binary in plugin settings (which is
> what I did I think?)
> Is there another place where I can set the plugin settings? Should I rename
> exiftool(-k).exe to exiftool?
> Regards,
Alexander Bruy
