[Qgis-user] plugin doesn't find exiftool executable
Reginald Carlier
Reginald.Carlier at ingelmunster.be
Tue Oct 4 05:42:08 PDT 2016
Hi Alexander,
I installed the plugin in QGIS 2.16.3.
When I run the 'Import photos' tool I point the ExifTool Config browse button to the exiftool(-k).exe that I have downloaded from
http://www.sno.phy.queensu.ca/~phil/exiftool/index.html
I installed the windows executable.
When running the 'Import photos' tool it gives following error:
Can't locate exiftool executable! Make sure it is installed and available in PATH or alternatively specify path to binary in plugin settings (which is what I did I think?)
Is there another place where I can set the plugin settings? Should I rename exiftool(-k).exe to exiftool?
Regards,
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161004/bac9d297/attachment.html>
