[Qgis-user] Points in polygon tool in QGIS 2.16?
DelazJ
delazj at gmail.com
Wed Oct 5 04:08:41 PDT 2016
Chris, have you activated Processing plugin?
That said, with Processing activated, I can't find it either in the Vector
menu; but you should find it in the toolbox from Processing menu and launch
it from there.
HTH,
Harrissou
2016-10-05 12:56 GMT+02:00 Chris Buckmaster <
chris.buckmaster at runnymede.gov.uk>:
> Hi
> I am just wondering whether the Points in Polygon tool has been moved to a
> different location in QGIS 2.16, or whether it has been superseded by a
> different tool?
> I need to count the number of points in polygons and the QGIS user guide
> seems to suggest there is a tool available under the Analysis Tools called
> Points in polygon, but I cannot seem to find it? Is this still available or
> do I need to install a plugin to access it?
> Thanks, Chris
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161005/5ca66589/attachment.html>
