[Qgis-user] QGIS Python install
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Fri Oct 7 06:08:14 PDT 2016
I remember reading that some packages will not install properly in the qgis Python programme and that adding new packages could break QGIS. I am not sure if there is still truth to that. In any case, I have started using Anaconda Python. It is installed with multiple scientific packages and has a nice GUI for installing more. Pip is also there for the other packages.
If you do install Anaconda, make sure you DO NOT click the "use Anaconda as the default Python" during the install. If you do, qgis will try to use the Anaconda and Qgis will crash. If you make that mistake, you will need to correct the windows local environment variables.
Nicolas
> Le 7 oct. 2016 à 07:29, Tyler Veinot-2 [via OSGeo.org] <ml-node+s1560n5289770h31 at n6.nabble.com> a écrit :
> All;
> Trying to add some modules to python and I didn't want to have multiple Python installs on my system; I would like to stick to the C:\Program Files\QGIS 2.16\apps\Python27 but I keep getting Python is not a recognized internal or external command, I get the same error when I try to install packages with pip.
> I was reading that the issue is the spaces in the C:\Program Files part, has anyone had a similar issue and know of a fix/work around?
> Thanks
> Tyler
> Qgis-user mailing list
> [hidden email]
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/QGIS-Python-install-tp5289770.html
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/QGIS-Python-install-tp5289770p5289788.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161007/517dd5cb/attachment.html>
