[Qgis-user] QGIS Python install
Tyler Veinot tylerkveinot at gmail.com
Fri Oct 7 08:14:02 PDT 2016
Nicholas;
I wasn't going to install Anaconda I never used it; I only ever used
Python27 installed with ArcGIS and QGIS. But I could not solve the issue so
I just installed a new Python in the C:\Python27 dir.
How does Anaconda and Python/IDLE differ?
Tyler
On Fri, Oct 7, 2016 at 10:08 AM, Nicolas Cadieux <
nicolas.cadieux at archeotec.ca> wrote:
> Hi,
> I remember reading that some packages will not install properly in the
> qgis Python programme and that adding new packages could break QGIS.  I am
> not sure if there is still truth to that.  In any case, I have started
> using Anaconda Python.   It is installed with multiple scientific packages
> and has a nice GUI for installing more.  Pip is also there for the other
> packages.
> If you do install Anaconda,  make sure you DO NOT click the "use Anaconda
> as the default Python" during the install.  If you do, qgis will try to use
> the Anaconda and Qgis will crash.  If you make that mistake, you will need
> to correct the windows local environment variables.
> Nicolas
> Le 7 oct. 2016 à 07:29, Tyler Veinot-2 [via OSGeo.org] <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5289788&i=0>> a écrit :
> All;
> Trying to add some modules to python and I didn't want to have multiple
> Python installs on my system; I would like to stick to the C:\Program
> Files\QGIS 2.16\apps\Python27 but I keep getting Python is not a recognized
> internal or external command, I get the same error when I try to install
> packages with pip.
> I was reading that the issue is the spaces in the C:\Program Files part,
> has anyone had a similar issue and know of a fix/work around?
> Thanks
> Tyler
> Qgis-user mailing list
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5289770&i=0>
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/QGIS-Python-install-tp5289770.html
> To start a new topic under Quantum GIS - User, email [hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5289788&i=1>
> To unsubscribe from Quantum GIS - User, click here.
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: Re: QGIS Python install
> <http://osgeo-org.1560.x6.nabble.com/QGIS-Python-install-tp5289770p5289788.html>
> Sent from the Quantum GIS - User mailing list archive
> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at
> Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161007/cfec6738/attachment.html>
