[Qgis-user] Attribut table in 2.16
    Even Rouault
    even.rouault at spatialys.com
    Fri Oct  7 08:47:53 PDT 2016
Le vendredi 07 octobre 2016 17:27:43, Pathin a écrit :
> Hello
> i have updated from 2.14.3 to 2.16 and got an issue i cant understand:
> I have imported a SQLite database to a vector layer what has worked
> fine. On this layer i have worked with the attribut table and select a
> specific line and zoomed in to the map.
> But now after the update the layer is available by the table, but not
> shown as a map anymore so i cant select a specific line anymore
> downgrade to 2.14.3 "solved" it so i can work again but i would like to
> share to it to the group
Mind sharing your database ? I've just tried with one of mine and that works
fine when using a Spatialite connection or when opening it throug Add vector
layer.
> thx
http://www.spatialys.com
