[Qgis-user] Fwd: How to enable GRASS7 in QGIS 2.16 on Mac?
wkent
wkent at medinaco.org
Fri Oct 7 11:30:11 PDT 2016
On 2016-09-29 8:45 am, Howard Frederick wrote:
> Recently upgraded to 2.16 - but cannot enable GRASS in the Processing
> configuration. Any ideas how to make this work?
> The folder seems to be correctly indicated in the config:
> /Applications/QGIS.app/Contents/MacOS/grass7
> This (and alternatives like ending as grass7/ ) give "This algorithm
> cannot be run :-(".
> Version: QGIS 2.16.2, on OS X 10.10.5.
Same error here, except running OS X 10.11.6. It seems to be a path
issue, although I have not been able to determine where the path is set.
Additionally, while QGIS is able to locate and open my existing GRASS
locations/mapsets, when I click on a GRASS layer in the browser panel to
add to the layers panel, QGIS crashes.
