[Qgis-user] How to enable GRASS7 in QGIS 2.16 on Mac?
William Kyngesburye woklist at kyngchaos.com
Fri Oct 7 14:51:46 PDT 2016
Loading GRASS data and using the GRASS toolbox are separate from using GRASS "algorithms" in the Processing plugin.
The Processing plugin needs to know where GRASS is (set in Processing options, but defaults to bundled GRASS 7), and runs GRASS commands in a separate process than QGIS (should not crash QGIS).
Loading GRASS data in QGIS needs no configuration of a GRASS path (this could crash QGIS if there is a bug or build problem).  Running GRASS modules does need configuration, but this also defaults to the bundled GRASS 7.  There is also a "general" GRASS option for the GRASS installation path, but this seems to default to the compiled GRASS location.  You can try setting this to the QGIS app:
  /Applications/QGIS.app/Contents/MacOS/grass7
If you still get a crash, a copy of the crash log would help figure out what's wrong.
> On Oct 7, 2016, at 1:30 PM, wkent <wkent at medinaco.org> wrote:
> On 2016-09-29 8:45 am, Howard Frederick wrote:
>> Recently upgraded to 2.16 - but cannot enable GRASS in the Processing configuration. Any ideas how to make this work?
>> The folder seems to be correctly indicated in the config: /Applications/QGIS.app/Contents/MacOS/grass7
>> This (and alternatives like ending as grass7/ ) give "This algorithm cannot be run :-(".
>> Version: QGIS 2.16.2, on OS X 10.10.5.
> Same error here, except running OS X 10.11.6.  It seems to be a path issue, although I have not been able to determine where the path is set.
> Additionally, while QGIS is able to locate and open my existing GRASS locations/mapsets, when I click on a GRASS layer in the browser panel to add to the layers panel, QGIS crashes.
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Those people who most want to rule people are, ipso-facto, those least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
