[Qgis-user] Jointure request
Karl-Magnus Jönsson Karl-Magnus.Jonsson at kristianstad.se
Thu Oct 13 04:10:23 PDT 2016
How do you do the spatial join? Are you using a database?
Karl-Magnus Jönsson
-----Ursprungligt meddelande-----
Från: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] För Erwan Conseil
Skickat: den 13 oktober 2016 13:02
Till: qgis-user at lists.osgeo.org
Ämne: Re: [Qgis-user] Jointure request
i forgot ...the geometries are correct ..
Le 13/10/2016 à 12:40, Erwan Conseil a écrit :
> Hi
> i a have a little pb with the jointures ... certainly simple ...but ..
> I try a spatial jointure between  a layer with buildings and a layer
> with plots of land  . With that , i try to have all the polts of land
> with a building ... So , i make a spatial jointure with " plots of
> land" contains " buildings" . But some plots are indeed in the layer
> of plots of land ( exist in the table and visible on the map ) . Also
> the buidings of these plots exist in the table of buiding ( and
> visible on the map ). But ...but , the spatial jointure give nothing
> for these plots and buiding ...On the map , i see the buiding , the
> plot but the plot dos'nt appear like a "plot with buiding"...
> The too layers are in the same projection ... I don't know wher is the
> pb and ..the solution !
> Thank a lot for the help !!
> Laurent
> ( precisions : work with a Mac and Qgis 2.16 )
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
