[Qgis-user] Jointure request
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Thu Oct 13 04:21:18 PDT 2016
Make sure don't have multi-polygones. Try "intersect" not "contain". What algorithm are you using (qgis,saga,grass...?)
Nicolas
> Le 13 oct. 2016 à 07:10, Karl-Magnus Jönsson [via OSGeo.org] <ml-node+s1560n5290549h80 at n6.nabble.com> a écrit :
> Hi,
> How do you do the spatial join? Are you using a database?
> Karl-Magnus Jönsson
> -----Ursprungligt meddelande-----
> Från: Qgis-user [mailto:[hidden email]] För Erwan Conseil
> Skickat: den 13 oktober 2016 13:02
> Till: [hidden email]
> Ämne: Re: [Qgis-user] Jointure request
> i forgot ...the geometries are correct ..
> Le 13/10/2016 à 12:40, Erwan Conseil a écrit :
> > Hi
> > i a have a little pb with the jointures ... certainly simple ...but ..
> > I try a spatial jointure between a layer with buildings and a layer
> > with plots of land . With that , i try to have all the polts of land
> > with a building ... So , i make a spatial jointure with " plots of
> > land" contains " buildings" . But some plots are indeed in the layer
> > of plots of land ( exist in the table and visible on the map ) . Also
> > the buidings of these plots exist in the table of buiding ( and
> > visible on the map ). But ...but , the spatial jointure give nothing
> > for these plots and buiding ...On the map , i see the buiding , the
> > plot but the plot dos'nt appear like a "plot with buiding"...
> > The too layers are in the same projection ... I don't know wher is the
> > pb and ..the solution !
> > Thank a lot for the help !!
> > Laurent
> > ( precisions : work with a Mac and Qgis 2.16 )
> Qgis-user mailing list
> [hidden email]
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> [hidden email]
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/Jointure-request-tp5290544p5290549.html
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Jointure-request-tp5290544p5290550.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161013/ddcea115/attachment.html>
