[Qgis-user] Jointure request
Erwan Conseil
erwanconseil at gmail.com
Thu Oct 13 06:23:21 PDT 2016
HI
thank for your answer !
So , il have checked the geometry : no multipolygones at all
I have also tried "intersect" : instead of having 3900 objects , i have
5500 ...but without the possibility to create a new layer ( a message of
error : not new layer with "FID" : a don'nt no what is it ...) The old
"bad"plots of land are now included in the selection but new one are
also present ...these news one have no building visible on the map If
you understand ...
Laurent
Le 13/10/2016 à 13:21, Nicolas Cadieux a écrit :
> Hi,
> Make sure don't have multi-polygones. Try "intersect" not "contain".
> What algorithm are you using (qgis,saga,grass...?)
> Nicolas
> Le 13 oct. 2016 à 07:10, Karl-Magnus Jönsson [via OSGeo.org
> <http://OSGeo.org>] <[hidden email]
> </user/SendEmail.jtp?type=node&node=5290550&i=0>> a écrit :
>> Hi,
>> How do you do the spatial join? Are you using a database?
>> Karl-Magnus Jönsson
>> -----Ursprungligt meddelande-----
>> Från: Qgis-user [mailto:[hidden email]
>> </user/SendEmail.jtp?type=node&node=5290549&i=0>] För Erwan Conseil
>> Skickat: den 13 oktober 2016 13:02
>> Till: [hidden email] </user/SendEmail.jtp?type=node&node=5290549&i=1>
>> Ämne: Re: [Qgis-user] Jointure request
>> i forgot ...the geometries are correct ..
>> Le 13/10/2016 à 12:40, Erwan Conseil a écrit :
>> > Hi
>> > i a have a little pb with the jointures ... certainly simple ...but ..
>> > I try a spatial jointure between a layer with buildings and a layer
>> > with plots of land . With that , i try to have all the polts of land
>> > with a building ... So , i make a spatial jointure with " plots of
>> > land" contains " buildings" . But some plots are indeed in the layer
>> > of plots of land ( exist in the table and visible on the map ) . Also
>> > the buidings of these plots exist in the table of buiding ( and
>> > visible on the map ). But ...but , the spatial jointure give nothing
>> > for these plots and buiding ...On the map , i see the buiding , the
>> > plot but the plot dos'nt appear like a "plot with buiding"...
>> > The too layers are in the same projection ... I don't know wher is the
>> > pb and ..the solution !
>> > Thank a lot for the help !!
>> > Laurent
>> > ( precisions : work with a Mac and Qgis 2.16 )
>> Qgis-user mailing list
>> [hidden email] </user/SendEmail.jtp?type=node&node=5290549&i=2>
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> [hidden email] </user/SendEmail.jtp?type=node&node=5290549&i=3>
>> If you reply to this email, your message will be added to the
>> discussion below:
>> http://osgeo-org.1560.x6.nabble.com/Jointure-request-tp5290544p5290549.html
>> To start a new topic under Quantum GIS - User, email [hidden email]
>> </user/SendEmail.jtp?type=node&node=5290550&i=1>
>> To unsubscribe from Quantum GIS - User, click here.
>> NAML
>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: Re: Jointure request
> <http://osgeo-org.1560.x6.nabble.com/Jointure-request-tp5290544p5290550.html>
> Sent from the Quantum GIS - User mailing list archive
> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html>
> at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161013/df6a2e5d/attachment.html>
