[Qgis-user] Jointure request
Erwan Conseil erwanconseil at gmail.com
Thu Oct 13 06:28:36 PDT 2016
suite : i used the Qgis tools like the "processing "plugin or "vector
menu" . I used also the Sqlte base for the data from the government but
the layer and request's result are only in a repertory in Dropbox ...
Le 13/10/2016 à 15:23, Erwan Conseil a écrit :
> HI
> thank for your answer !
> So , il have checked the geometry : no multipolygones at all
> I have also tried "intersect" : instead of having 3900 objects , i
> have 5500 ...but without the possibility to create a new layer ( a
> message of error : not new layer with "FID" : a don'nt no what is it
> ...)  The old "bad"plots of land are now included in the selection but
> new one are also present ...these news one have no building visible on
> the map If you understand ...
> Laurent
> Le 13/10/2016 à 13:21, Nicolas Cadieux a écrit :
>> Hi,
>> Make sure don't have multi-polygones.  Try "intersect" not "contain".
>>   What algorithm are you using (qgis,saga,grass...?)
>> Nicolas
>> Le 13 oct. 2016 à 07:10, Karl-Magnus Jönsson [via OSGeo.org
>> <http://OSGeo.org>] <[hidden email]
>> </user/SendEmail.jtp?type=node&node=5290550&i=0>> a écrit :
>>> Hi,
>>> How do you do the spatial join? Are you using a database?
>>> Karl-Magnus Jönsson
>>> -----Ursprungligt meddelande-----
>>> Från: Qgis-user [mailto:[hidden email]
>>> </user/SendEmail.jtp?type=node&node=5290549&i=0>] För Erwan Conseil
>>> Skickat: den 13 oktober 2016 13:02
>>> Till: [hidden email] </user/SendEmail.jtp?type=node&node=5290549&i=1>
>>> Ämne: Re: [Qgis-user] Jointure request
>>> i forgot ...the geometries are correct ..
>>> Le 13/10/2016 à 12:40, Erwan Conseil a écrit :
>>> > Hi
>>> > i a have a little pb with the jointures ... certainly simple
>>> ...but ..
>>> > I try a spatial jointure between  a layer with buildings and a layer
>>> > with plots of land  . With that , i try to have all the polts of land
>>> > with a building ... So , i make a spatial jointure with " plots of
>>> > land" contains " buildings" . But some plots are indeed in the layer
>>> > of plots of land ( exist in the table and visible on the map ) . Also
>>> > the buidings of these plots exist in the table of buiding ( and
>>> > visible on the map ). But ...but , the spatial jointure give nothing
>>> > for these plots and buiding ...On the map , i see the buiding , the
>>> > plot but the plot dos'nt appear like a "plot with buiding"...
>>> > The too layers are in the same projection ... I don't know wher is
>>> the
>>> > pb and ..the solution !
>>> > Thank a lot for the help !!
>>> > Laurent
>>> > ( precisions : work with a Mac and Qgis 2.16 )
>>> Qgis-user mailing list
>>> [hidden email] </user/SendEmail.jtp?type=node&node=5290549&i=2>
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> [hidden email] </user/SendEmail.jtp?type=node&node=5290549&i=3>
>>> If you reply to this email, your message will be added to the
>>> discussion below:
>>> http://osgeo-org.1560.x6.nabble.com/Jointure-request-tp5290544p5290549.html
>>> To start a new topic under Quantum GIS - User, email [hidden email]
>>> </user/SendEmail.jtp?type=node&node=5290550&i=1>
>>> To unsubscribe from Quantum GIS - User, click here.
>>> NAML
>>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>> View this message in context: Re: Jointure request
>> <http://osgeo-org.1560.x6.nabble.com/Jointure-request-tp5290544p5290550.html>
>> Sent from the Quantum GIS - User mailing list archive
>> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html>
>> at Nabble.com.
>> List info:http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161013/e2cd4d4d/attachment.html>
