[Qgis-user] inconsistenty when calculating area depending on file type or projection?
Carlos Cerdán
sig.upagu at gmail.com
Fri Oct 14 07:51:46 PDT 2016
Hi Nyall
I'm afraid that 2.16 has still this issue. I've loaded an UTM-17 south
layer (my zone) and a Lat-long layer and:
1. SRC was seted in UTM
2. In UTM layer, if OTF SRC transformation is active, I get different area
than if it's deactivated. Correct value is the last one.
3. In Lat-long layer, if OTF SRC transformation is active, calculated area
is same as the wrong value of first layer. I can't get the correct value in
this layer, so I have to reproject into a new one and do step 2 (with OTF
deactivated).
What about a general option to set the prefered SRC to calculate areas and
lengths with OTF active?
Regards from Peru
Carlos
2016-10-12 18:06 GMT-05:00 Nyall Dawson <nyall.dawson at gmail.com>:
> On 12 Oct 2016 11:56 PM, "Carlos Cerdán" <sig.upagu at gmail.com> wrote:
> > AFAIK, It also is needed to turn off "on the fly SRC transformation" to
> get correct area values.... Or QGIS has fixed this point?
> Everything should be fixed in recent versions, and I very (VERY) much want
> to know if any issues are still encountered.
> Calculating area/length is a core task for a GIS and we need to make sure
> it's rock solid. (Which it should be since 2.16!)
> Nyall
> > If you can't get correct area values, check out about it....
> > 2016-10-12 7:40 GMT-05:00 DelazJ <delazj at gmail.com>:
> >> Hi,
> >> To complete Nicolas answer, you should check what are the measurements
> options set in Project --> Project Properties --> General tab.
> >> See also http://docs.qgis.org/2.14/en/docs/user_manual/introduction/g
> eneral_tools.html#measuring
> >> 2016-10-12 14:07 GMT+02:00 Nicolas Cadieux <
> nicolas.cadieux at archeotec.ca>:
> >>> Hi,
> >>> You may be calculating square degrees and not metres. It can depend
> on the crs depending on the tools you are using.
> >>> Nicolas
> >>> Le 11 oct. 2016 à 08:54, Martina Schäfer [via OSGeo.org] <[hidden
> email]> a écrit :
> >>>> I experienced some confusion with calculation of area using the field
> calculator in QGIS version 2.16.3. Since I'm using MapInfo Professional as
> well, I mainly use tab-files that I can open in both programmes, but
> occasionally I save as shapefile since this used to be the default in QGIS.
> >>>> When comparing files, I coincidently realized that there was a
> mismatch in calculated area for the shapefile and the tab-file for exactly
> the same polygons! I used the field calculator in the attribute table in
> both cases, but for the shapefile the resulting areas were almost doubled
> in area compared to the tab-file. Any idea why this is happening?
> >>>> I also realized similar differences when calculating area in a file
> where projection has been converted from SWEREF99TM (a Swedish national
> projection) to WGS84. There differences occurred in both the tab and
> shapefile compared to the area calculated for the same tab-file in MapInfo.
> Again I find this very confusing!
> >>>> I need to rely on the area-calculations thus I really hope someone
> here can explain to me what is happening!
> >>>> Thanks in advance,
> >>>> Martina
> >>>> ________________________________
> >>>> If you reply to this email, your message will be added to the
> discussion below:
> >>>> http://osgeo-org.1560.x6.nabble.com/inconsistenty-when-calcu
> lating-area-depending-on-file-type-or-projection-tp5290228.html
> >>>> To start a new topic under Quantum GIS - User, email [hidden email]
> >>>> To unsubscribe from Quantum GIS - User, click here.
> >>>> NAML
> >>> View this message in context: Re: inconsistenty when calculating area
> >>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> >>> _______________________________________________
> >>> Qgis-user mailing list
> >>> Qgis-user at lists.osgeo.org
> >>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> >>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161014/cbe4a84e/attachment.html>
