[Qgis-user] Jointure request
DelazJ delazj at gmail.com
Fri Oct 14 08:15:41 PDT 2016
Nicolas, have you removed the old version of Processing plugin from your
user /.qgis2/python/plugins folder?
Regards,
Harrissou
2016-10-13 16:24 GMT+02:00 Nicolas Cadieux <nicolas.cadieux at archeotec.ca>:
> Then I must have a bad install...
> Le 13 oct. 2016 à 10:03, DelazJ [via OSGeo.org] <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5290582&i=0>> a écrit :
> Hi,
> 2016-10-13 15:53 GMT+02:00 Nicolas Cadieux <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5290574&i=0>>:
>> Hi,
>> If you have a clean install of 2.16, you should not have the vector menu
>> for those tool.  They should be only be found in the  processing toolbox.
> Not really true. The old Ftools algorithms in Vector menu have been
> removed and replaced by Processing ones but to ease access to these Toolbox
> functions (and to not confuse people), paths through the Vector menu are
> kept. So (the same) functions are available in vector menu and Processing
> toolbox.
> http://qgis.org/en/site/forusers/visualchangelog216/
> index.html#feature-ftools-plugin-has-been-replaced-with-
> processing-algorithms
> Regards,
> Harrissou
>>  If you have it in both places, I would destroy the registry keys and
>> destroy or rename (better) the .qgis folders found for every user in the
>> machine.  I should be a hidden file.  That will reset qgis and take away a
>> possible mess that happens with the processing toolbox.  You will need to
>> reinstall all the plugins or copy them back.  Just don't copy the
>> processing folders.
>> You could try moving the data to a local drive, not a Dropbox.  You could
>> try on a smaller sample to find the source of the errors or try to export
>> to a shape file and try again.
>> Google the error
>> http://gis.stackexchange.com/questions/153668/spatial-query-
>> the-query-from-layername-using-fid-in-field-not-possible
>> There could be other tools you could use in saga or grass (via processing
>> tb).  Try saga first.
>> Good luck
>> Nicolas
>> Le 13 oct. 2016 à 09:29, Erwan Conseil [via OSGeo.org] <[hidden email]
>> <http:///user/SendEmail.jtp?type=node&node=5290570&i=0>> a écrit :
>> suite : i used the Qgis tools like the "processing "plugin or "vector
>> menu" . I used also the Sqlte base for the data from the government but the
>> layer and request's result are only in a repertory in Dropbox ...
>> Le 13/10/2016 à 15:23, Erwan Conseil a écrit :
>> HI
>> thank for your answer !
>> So , il have checked the geometry : no multipolygones at all
>> I have also tried "intersect" : instead of having 3900 objects , i have
>> 5500 ...but without the possibility to create a new layer ( a message of
>> error : not new layer with "FID" : a don'nt no what is it ...)  The old
>> "bad"plots of land are now included in the selection but new one are also
>> present ...these news one have no building visible on the map If you
>> understand ...
>> Laurent
>> Le 13/10/2016 à 13:21, Nicolas Cadieux a écrit :
>> Hi,
>> Make sure don't have multi-polygones.  Try "intersect" not "contain".
>> What algorithm are you using (qgis,saga,grass...?)
>> Nicolas
>> Le 13 oct. 2016 à 07:10, Karl-Magnus Jönsson [via OSGeo.org] <[hidden
>> email] <http:///user/SendEmail.jtp?type=node&node=5290550&i=0>> a écrit :
>> Hi,
>> How do you do the spatial join? Are you using a database?
>> Karl-Magnus Jönsson
>> -----Ursprungligt meddelande-----
>> Från: Qgis-user [mailto:[hidden email]
>> <http:///user/SendEmail.jtp?type=node&node=5290549&i=0>] För Erwan
>> Conseil
>> Skickat: den 13 oktober 2016 13:02
>> Till: [hidden email]
>> <http:///user/SendEmail.jtp?type=node&node=5290549&i=1>
>> Ämne: Re: [Qgis-user] Jointure request
>> i forgot ...the geometries are correct ..
>> Le 13/10/2016 à 12:40, Erwan Conseil a écrit :
>> > Hi
>> > i a have a little pb with the jointures ... certainly simple ...but ..
>> > I try a spatial jointure between  a layer with buildings and a layer
>> > with plots of land  . With that , i try to have all the polts of land
>> > with a building ... So , i make a spatial jointure with " plots of
>> > land" contains " buildings" . But some plots are indeed in the layer
>> > of plots of land ( exist in the table and visible on the map ) . Also
>> > the buidings of these plots exist in the table of buiding ( and
>> > visible on the map ). But ...but , the spatial jointure give nothing
>> > for these plots and buiding ...On the map , i see the buiding , the
>> > plot but the plot dos'nt appear like a "plot with buiding"...
>> > The too layers are in the same projection ... I don't know wher is the
>> > pb and ..the solution !
>> > Thank a lot for the help !!
>> > Laurent
>> > ( precisions : work with a Mac and Qgis 2.16 )
>> Qgis-user mailing list
>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5290549&i=2>
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5290549&i=3>
>> If you reply to this email, your message will be added to the discussion
>> below:
>> http://osgeo-org.1560.x6.nabble.com/Jointure-request-tp52905
>> 44p5290549.html
>> To start a new topic under Quantum GIS - User, email [hidden email]
>> <http:///user/SendEmail.jtp?type=node&node=5290550&i=1>
>> To unsubscribe from Quantum GIS - User, click here.
>> NAML
>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>> View this message in context: Re: Jointure request
>> <http://osgeo-org.1560.x6.nabble.com/Jointure-request-tp5290544p5290550.html>
>> Sent from the Quantum GIS - User mailing list archive
>> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at
>> Nabble.com.
>> Qgis-user mailing list[hidden email] <http:///user/SendEmail.jtp?type=node&node=5290567&i=0>
>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5290567&i=1>
>> below:
>> 44p5290567.html
>> <http:///user/SendEmail.jtp?type=node&node=5290570&i=1>
>> NAML
>> <http://osgeo-org.1560.x6.nabble.com/Jointure-request-tp5290544p5290570.html>
>> Nabble.com.
>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5290574&i=1>
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5290574&i=2>
> below:
> tp5290544p5290574.html
> <http:///user/SendEmail.jtp?type=node&node=5290582&i=1>
> NAML
> <http://osgeo-org.1560.x6.nabble.com/Jointure-request-tp5290544p5290582.html>
> Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161014/5fcaf6ab/attachment.html>
