[Qgis-user] inconsistenty when calculating area depending on file type or projection?
Nyall Dawson
nyall.dawson at gmail.com
Tue Oct 18 17:58:58 PDT 2016
On 19 October 2016 at 02:22, Carlos Cerdán <sig.upagu at gmail.com> wrote:
> It was my fault. I was used to consider plane areas as "correct", forgetting
> ellipsoidal areas. So, QGIS give us freedom to calculate planar or
> ellipsoidal (geodetical) areas, but we must be careful about settings; Is
> not it?. Sometimes, too much freedom is annoying!
> But, How can I calculate UTM (planar) area from a GEO layer in one step?
Under project properties, general tab - change "ellipsoid" to "None /
Planimetric".
I keep meaning to split up the concept of ellipsoidal measurement from
OTF reprojection. In my view these are two different concepts - one is
just about display of data, the other relates to measurement. Ie, you
should be able to perform ellipsoidal calculations even if OTF
rendering is disabled.
I just keep forgetting to do it early in a release cycle for extensive
testing...
Nyall
> Thank you very much for your time and so sorry if I'm doing basic questions.
> Carlos
> 2016-10-16 17:59 GMT-05:00 Nyall Dawson <nyall.dawson at gmail.com>:
>> On 16 October 2016 at 05:20, Carlos Cerdán <sig.upagu at gmail.com> wrote:
>> > Hi Nyall (and list)
>> > A small projecto with UTM and GEO layers can be downloaded from dropbox:
>> > https://www.dropbox.com/s/c4cfb48r5326vrk/Cajamarca.zip?dl=0
>> > Attribute table has the correct area in AreaKm2 field (and in these
>> > unities). "AreaOTFoff" is the area given by field calculator when "On
>> > The
>> > Fly transformation" is deactivated. "AreaOTF_on" is the area with it
>> > activated.
>> > So: when I have a GEO layer, I can't calculate correct area directly in
>> > that
>> > layer: I've to reproject to UTM and deactivate automatic transformation
>> > of
>> > SRCs, to use field calculator expecting correct values.
>> > OS : Ubuntu 16.04
>> > QGIS : 2.16.3
>> > SRC settings: by default (ellipsoide WGS84 for measures)
>> Thanks for sending this through, but again - I can't find any issue here.
>> The different area calculations come from the difference between
>> measuring the area using a flat plane (OTF off, no ellipsoid set) vs
>> measuring the area using an ellipsoid (OTF on, ellipsoid set under the
>> project "general" settings). When OTF is on QGIS calculates the same
>> area regardless of whether the geographic or projected source layer is
>> used.
>> Hope that clarifies!
>> Nyall
>> > Thank you for your interest
>> > Carlos Cerdán
>> > 2016-10-14 15:14 GMT-05:00 Nyall Dawson <nyall.dawson at gmail.com>:
>> >> On 15 Oct 2016 12:51 AM, "Carlos Cerdán" <sig.upagu at gmail.com> wrote:
>> >> > Hi Nyall
>> >> > I'm afraid that 2.16 has still this issue. I've loaded an UTM-17
>> >> > south
>> >> > layer (my zone) and a Lat-long layer and:
>> >> > 1. SRC was seted in UTM
>> >> > 2. In UTM layer, if OTF SRC transformation is active, I get different
>> >> > area than if it's deactivated. Correct value is the last one.
>> >> > 3. In Lat-long layer, if OTF SRC transformation is active, calculated
>> >> > area is same as the wrong value of first layer. I can't get the
>> >> > correct
>> >> > value in this layer, so I have to reproject into a new one and do
>> >> > step 2
>> >> > (with OTF deactivated).
>> >> > What about a general option to set the prefered SRC to calculate
>> >> > areas
>> >> > and lengths with OTF active?
>> >> Hi Carlos,
>> >> Can you please share your file? Cut it down to just a few polygons and
>> >> let
>> >> me know what area you expect to see. Email direct to myself.
>> >> Thanks!
>> >> Nyall
>> >> > Regards from Peru
>> >> > Carlos
>> >> > 2016-10-12 18:06 GMT-05:00 Nyall Dawson <nyall.dawson at gmail.com>:
>> >> >> On 12 Oct 2016 11:56 PM, "Carlos Cerdán" <sig.upagu at gmail.com>
>> >> >> wrote:
>> >> >> > AFAIK, It also is needed to turn off "on the fly SRC
>> >> >> > transformation"
>> >> >> > to get correct area values.... Or QGIS has fixed this point?
>> >> >> Everything should be fixed in recent versions, and I very (VERY)
>> >> >> much
>> >> >> want to know if any issues are still encountered.
>> >> >> Calculating area/length is a core task for a GIS and we need to make
>> >> >> sure it's rock solid. (Which it should be since 2.16!)
>> >> >> Nyall
>> >> >> > If you can't get correct area values, check out about it....
>> >> >> > 2016-10-12 7:40 GMT-05:00 DelazJ <delazj at gmail.com>:
>> >> >> >> Hi,
>> >> >> >> To complete Nicolas answer, you should check what are the
>> >> >> >> measurements options set in Project --> Project Properties -->
>> >> >> >> General tab.
>> >> >> >> See also
>> >> >> >> http://docs.qgis.org/2.14/en/docs/user_manual/introduction/general_tools.html#measuring
>> >> >> >> 2016-10-12 14:07 GMT+02:00 Nicolas Cadieux
>> >> >> >> <nicolas.cadieux at archeotec.ca>:
>> >> >> >>> Hi,
>> >> >> >>> You may be calculating square degrees and not metres. It can
>> >> >> >>> depend on the crs depending on the tools you are using.
>> >> >> >>> Nicolas
>> >> >> >>> Le 11 oct. 2016 à 08:54, Martina Schäfer [via OSGeo.org]
>> >> >> >>> <[hidden
>> >> >> >>> email]> a écrit :
>> >> >> >>>> I experienced some confusion with calculation of area using the
>> >> >> >>>> field calculator in QGIS version 2.16.3. Since I'm using
>> >> >> >>>> MapInfo
>> >> >> >>>> Professional as well, I mainly use tab-files that I can open in
>> >> >> >>>> both
>> >> >> >>>> programmes, but occasionally I save as shapefile since this
>> >> >> >>>> used to be the
>> >> >> >>>> default in QGIS.
>> >> >> >>>> When comparing files, I coincidently realized that there was a
>> >> >> >>>> mismatch in calculated area for the shapefile and the tab-file
>> >> >> >>>> for exactly
>> >> >> >>>> the same polygons! I used the field calculator in the attribute
>> >> >> >>>> table in
>> >> >> >>>> both cases, but for the shapefile the resulting areas were
>> >> >> >>>> almost doubled in
>> >> >> >>>> area compared to the tab-file. Any idea why this is happening?
>> >> >> >>>> I also realized similar differences when calculating area in a
>> >> >> >>>> file where projection has been converted from SWEREF99TM (a
>> >> >> >>>> Swedish national
>> >> >> >>>> projection) to WGS84. There differences occurred in both the
>> >> >> >>>> tab and
>> >> >> >>>> shapefile compared to the area calculated for the same tab-file
>> >> >> >>>> in MapInfo.
>> >> >> >>>> Again I find this very confusing!
>> >> >> >>>> I need to rely on the area-calculations thus I really hope
>> >> >> >>>> someone
>> >> >> >>>> here can explain to me what is happening!
>> >> >> >>>> Thanks in advance,
>> >> >> >>>> Martina
>> >> >> >>>> ________________________________
>> >> >> >>>> If you reply to this email, your message will be added to the
>> >> >> >>>> discussion below:
>> >> >> >>>> http://osgeo-org.1560.x6.nabble.com/inconsistenty-when-calculating-area-depending-on-file-type-or-projection-tp5290228.html
>> >> >> >>>> To start a new topic under Quantum GIS - User, email [hidden
>> >> >> >>>> email]
>> >> >> >>>> To unsubscribe from Quantum GIS - User, click here.
>> >> >> >>>> NAML
>> >> >> >>> View this message in context: Re: inconsistenty when calculating
>> >> >> >>> Sent from the Quantum GIS - User mailing list archive at
>> >> >> >>> Nabble.com.
>> >> >> >>> _______________________________________________
>> >> >> >>> Qgis-user mailing list
>> >> >> >>> Qgis-user at lists.osgeo.org
>> >> >> >>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> >> >> >>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
