[Qgis-user] Composer Atlas: How get rid of the big red cross when there is no image?
Nyall Dawson
nyall.dawson at gmail.com
Wed Oct 26 13:57:41 PDT 2016
On 27 Oct 2016 6:51 AM, "Bernd Vogelgesang" <bernd.vogelgesang at gmx.de>
wrote:
> Arghh, sorry for the noise!
> When hovering over the data-driven input button not so hectically, I
discovered the explanation that it expects a 0 or 1.
> So
> case when
> 'mypath'|| @atlas_pagename ||'_1.jpeg' IS NULL
> THEN
> 0
> END
> did the trick!
This is odd... A null picture expression should be rendered empty, not as
the red cross. The red cross is intended only as an obnoxious, obvious
indicator that a picture path was set but couldn't be found.
The expression above would only result in 0 if @atlas_pagename is null.
Nyall
> Just amazing!!!
> Thanx
> Bernd
> Am 26.10.2016, 22:19 Uhr, schrieb DelazJ <delazj at gmail.com>:
>> Hi,
>> what about using the data-defined option near the "Exclude items from
export" in the items properties --> Rendering (with a case when expression)?
http://docs.qgis.org/2.14/en/docs/user_manual/print_composer/composer_items/composer_items_options.html#rendering-mode
>> HTH,
>> Harrissou
>> 2016-10-26 22:10 GMT+02:00 Bernd Vogelgesang <bernd.vogelgesang at gmx.de>:
>>> Hi,
>>> I set up a neat atlas for displaying a row of 50 sample plots. On a
second page, I want to show 2 pictures taken of these plots automatically
with an expression including the path || @atlas_pagenumber || '_1.jpeg' or
'_2.jpeg' to display up to two photos named e.g. 1_1.jpeg, 1_2.jpeg.
>>> This works really great! The problem is, that for some plots, we do not
and have any picture or only one. In composer, these missing images are
marked with a big red cross.
>>> Unfortunately, these red crosses are also exported, which looks quite
shitty.
>>> Is there any clever way of forcing QGIS not to export these place
holders but just not to print anything at this place?
>>> The only (boring) idea I came up with till now, was to create empty
white images and name them accordingly to avoid the red crosses.
>>> Thanx
>>> Bernd
>>> Bernd Vogelgesang
>>> Siedlerstraße 2
>>> 91083 Baiersdorf/Igelsdorf
>>> Tel: 09133-825374
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Bernd Vogelgesang
> Siedlerstraße 2
> Tel: 09133-825374
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161027/08e3d536/attachment.html>
