[Qgis-user] Composer Atlas: How get rid of the big red cross when there is no image?
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Wed Oct 26 14:17:55 PDT 2016
Am 26.10.2016, 22:57 Uhr, schrieb Nyall Dawson <nyall.dawson at gmail.com>:
> On 27 Oct 2016 6:51 AM, "Bernd Vogelgesang" <bernd.vogelgesang at gmx.de>
> wrote:
>> Arghh, sorry for the noise!
>> When hovering over the data-driven input button not so hectically, I
>> discovered the explanation that it expects a 0 or 1.
>> So
>> case when'mypath'|| @atlas_pagename ||'_1.jpeg' IS NULL
>> THEN
>> 0
>> END
>> did the trick!
> This is odd... A null picture expression should be rendered empty, not
> as the red cross. The red cross is intended only as an >obnoxious,
> obvious indicator that a picture path was set but couldn't be found.
> The expression above would only result in 0 if @atlas_pagename is null.
> Nyall
Well, yeah, I was too early to announce the solution. In fact this did not
render the missing image, but also not the one which is there :(
case when
'/media/Daten/IVL_Projekte/2016024_Feldhamster_NEA/2_EINGANG_MA/Bernd/QGIS/Fotos/'||
THEN
1
ELSE
0
END
This should do it. But now I am again where is started: When the image is
there, it is rendered, when not, the red cross is exported as well.
Bernd
>> Just amazing!!!
>> Thanx
>> Bernd
>> Am 26.10.2016, 22:19 Uhr, schrieb DelazJ <delazj at gmail.com>:
>>> Hi,
>>> what about using the data-defined option near the "Exclude items from
>>> export" in the items properties --> Rendering (with a case >when
>>> expression)?
>>> http://docs.qgis.org/2.14/en/docs/user_manual/print_composer/composer_items/composer_items_options.html#rendering-mode
>>> HTH,
>>> Harrissou
>>> 2016-10-26 22:10 GMT+02:00 Bernd Vogelgesang
>>> <bernd.vogelgesang at gmx.de>:
>>>> Hi,
>>>> I set up a neat atlas for displaying a row of 50 sample plots. On a
>>>> second page, I want to show 2 pictures taken of these plots
>>>> >automatically with an expression including the path ||
>>>> @atlas_pagenumber || '_1.jpeg' or '_2.jpeg' to display up to two
>>>> photos named >e.g. 1_1.jpeg, 1_2.jpeg.
>>>> This works really great! The problem is, that for some plots, we do
>>>> not and have any picture or only one. In composer, these >missing
>>>> images are marked with a big red cross.
>>>> Unfortunately, these red crosses are also exported, which looks quite
>>>> shitty.
>>>> Is there any clever way of forcing QGIS not to export these place
>>>> holders but just not to print anything at this place?
>>>> The only (boring) idea I came up with till now, was to create empty
>>>> white images and name them accordingly to avoid the red >crosses.
>>>> Thanx
>>>> Bernd
>>>> --Bernd Vogelgesang
>>>> Siedlerstraße 2
>>>> 91083 Baiersdorf/Igelsdorf
>>>> Tel: 09133-825374
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Bernd Vogelgesang
>> Siedlerstraße 2
>> Tel: 09133-825374
Bernd Vogelgesang
Siedlerstraße 2
Tel: 09133-825374
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161026/45294731/attachment.html>
