[Qgis-user] Composer Atlas: How get rid of the big red cross when there is no image?
Nyall Dawson nyall.dawson at gmail.com
Wed Oct 26 15:12:32 PDT 2016
On 27 Oct 2016 7:18 AM, "Bernd Vogelgesang" <bernd.vogelgesang at gmx.de>
wrote:
> Am 26.10.2016, 22:57 Uhr, schrieb Nyall Dawson <nyall.dawson at gmail.com>:
>> On 27 Oct 2016 6:51 AM, "Bernd Vogelgesang" <bernd.vogelgesang at gmx.de>
wrote:
>> > Arghh, sorry for the noise!
>> > When hovering over the data-driven input button not so hectically, I
discovered the explanation that it expects a 0 or 1.
>> > So
>> > case when
>> > 'mypath'|| @atlas_pagename ||'_1.jpeg' IS NULL
>> > THEN
>> > 0
>> > END
>> > did the trick!
>> This is odd... A null picture expression should be rendered empty, not
as the red cross. The red cross is intended only as an obnoxious, obvious
indicator that a picture path was set but couldn't be found.
>> The expression above would only result in 0 if @atlas_pagename is null.
>> Nyall
> Well, yeah, I was too early to announce the solution. In fact this did
not render the missing image, but also not the one which is there :(
> case when
'/media/Daten/IVL_Projekte/2016024_Feldhamster_NEA/2_EINGANG_MA/Bernd/QGIS/Fotos/'||
> THEN
> 1
> ELSE
> 0
> END
> This should do it. But now I am again where is started: When the image is
there, it is rendered, when not, the red cross is exported as well.
That's because that expression is just testing whether the concatenated
string itself is null, not whether the corresponding file actually exists.
My advice: make a small python custom function 'file_exists' which checks
for the existence of a file. Then change your picture path expression to
something like:
Case when file_exists( 'media/' ... Etc) then  'media/' ... Else null end
That should get you the result you are after.
Nyall
> Bernd
>> > Just amazing!!!
>> > Thanx
>> > Bernd
>> > Am 26.10.2016, 22:19 Uhr, schrieb DelazJ <delazj at gmail.com>:
>> >> Hi,
>> >> what about using the data-defined option near the "Exclude items from
export" in the items properties --> Rendering (with a case when expression)?
http://docs.qgis.org/2.14/en/docs/user_manual/print_composer/composer_items/composer_items_options.html#rendering-mode
>> >> HTH,
>> >> Harrissou
>> >> 2016-10-26 22:10 GMT+02:00 Bernd Vogelgesang <bernd.vogelgesang at gmx.de
>> >>> Hi,
>> >>> I set up a neat atlas for displaying a row of 50 sample plots. On a
second page, I want to show 2 pictures taken of these plots automatically
with an expression including the path || @atlas_pagenumber || '_1.jpeg' or
'_2.jpeg' to display up to two photos named e.g. 1_1.jpeg, 1_2.jpeg.
>> >>> This works really great! The problem is, that for some plots, we do
not and have any picture or only one. In composer, these missing images are
marked with a big red cross.
>> >>> Unfortunately, these red crosses are also exported, which looks
quite shitty.
>> >>> Is there any clever way of forcing QGIS not to export these place
holders but just not to print anything at this place?
>> >>> The only (boring) idea I came up with till now, was to create empty
white images and name them accordingly to avoid the red crosses.
>> >>> Thanx
>> >>> Bernd
>> >>> Bernd Vogelgesang
>> >>> Siedlerstraße 2
>> >>> 91083 Baiersdorf/Igelsdorf
>> >>> Tel: 09133-825374
>> >>> _______________________________________________
>> >>> Qgis-user mailing list
>> >>> Qgis-user at lists.osgeo.org
>> >>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> >>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> > Bernd Vogelgesang
>> > Siedlerstraße 2
>> > Tel: 09133-825374
> Bernd Vogelgesang
> Siedlerstraße 2
> Tel: 09133-825374
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161027/f0e3833f/attachment.html>
