[Qgis-user] Qgis2web help needed
Joris Hintjens
jorishin at gmail.com
Sun Oct 30 16:12:11 PDT 2016
nope, you’re the first to answer my question. Still waiting
thanks
Joris
> Op 29 okt. 2016, om 13:59 heeft Mike Flannigan <mikeflan at att.net> het volgende geschreven:
> I'm sure you already received an answer to this, but
> I didn't see it.
> I opened your file, did a save in my 2.14.3-Essen on
> Win10 64 bit, closed QGIS, opened your file again, did
> a QGIS2Web export and the result is:
> www.mflan.com/temp/refuge/index.html
> So it didn't work for me either.
> Hopefully I will find where somebody else solved
> this problem.
> Mike
> On 10/18/2016 10:14 AM, qgis-user-request at lists.osgeo.org wrote:
>> Hi,
>> All info about my issue:
>> I made a nice map, which’d like to publish online.
>> my map gives no result when trying to export with QGIS2Web.
>> I’m just a poor lonesome mapper, and know nothing about coding, I cannot even define what the issue is.
>> more info at
>> https://dl.dropboxusercontent.com/u/23700421/refugeemapData.zip
>> with this link you can find:
>> - A consolidated project including all data (made in QGIS 2.14 on MacOS10.11)
>> -some screen grabs from the Qgis2web UI with results and/or error messages
>> as you can see, result is far from the original.
>> Thanks for having a look at it.
>> joris
