[Qgis-user] Qgis2web help needed
Mike Flannigan
mikeflan at att.net
Sun Oct 30 16:32:29 PDT 2016
I suspect you already received an answer to this, but
I didn't see it.
I opened your file, did a save in my 2.14.3-Essen on
Win10 64 bit, closed QGIS, opened your file again, did
a QGIS2Web export and the result is:
www.mflan.com/temp/refuge/index.html
So it didn't work for me either.
Hopefully I will find where somebody else solved
this problem.
Mike
On 10/18/2016 10:14 AM, qgis-user-request at lists.osgeo.org wrote:
> Hi,
> All info about my issue:
> I made a nice map, which’d like to publish online.
> my map gives no result when trying to export with QGIS2Web.
> I’m just a poor lonesome mapper, and know nothing about coding, I
> cannot even define what the issue is.
> more info at
> https://dl.dropboxusercontent.com/u/23700421/refugeemapData.zip
> with this link you can find:
> - A consolidated project including all data (made in QGIS 2.14 on
> MacOS10.11)
> -some screen grabs from the Qgis2web UI with results and/or error
> messages
> as you can see, result is far from the original.
> Thanks for having a look at it.
> joris
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20161030/32f7e589/attachment.html>
