On 2016-09-01 15:56, Ronen Pelleg wrote: > getting this error when trying to download map files where are you getting the map files from? is your internet connection ok? try accessing the map files from some other source, e.g. if they are openstreetmap files, see if you can access openstreetmap.org -- robin
