[Qgis-user] QGIS - help: filled contour lines from raster layer	data
    Nicolas Cadieux
    nicolas.cadieux at archeotec.ca
    Thu Sep  8 10:57:05 PDT 2016
I am not sure why you get that error but the r.contour.level will give you what you need if you select "area" in the v.out.org parameter.  That will give you polygons that you can color the fill area. If you have installed the latest version of Qgis, your processing toolbox could be a mix of old and new tools.  If this is the case, I would do complete reinstall deleting all the old plugins.
Nicolas
Envoyé de mon iPad
> Le 8 sept. 2016 à 08:47, KOHLMANN Hannes [via OSGeo.org] <ml-node+s1560n5284720h81 at n6.nabble.com> a écrit :
> Hello dear QGis users!
> A collegue and me were wondering if it is possible to create contour lines, or more important for us, FILLED contour lines (areas) for RASTER LAYER data!
> We are both very positive that this once worked and we have done that. Now we cannot find the way to reproduce that anymore.
> On the one hand, we thought that we had done it with the gdal-Contour tool in QGIS (Raster->Extract->Contour), but now we can’t find an option to generate filled contour areas, like
> it is possible with the installable extension „Contour Plugin“ (which is only possible to use with a point vector layer, but this is exactly what we think that we have done to a raster layer file!).
> 1)      Now the question: was that ever possible to do with the gdal-contour plugin? Or not…
> 2)      On the other hand, we also tried to use the GRASS Gis algorithms r.contour.level or r.contour.step, etc in the processing toolbox, but they keep giving us the error message: „environment can only contain strings See log for more details“. What ist he problem here? Does it have to do with the new version Grass Gis 7?
> 3)      Bottom line is: We have got a .dat file, which is a raster layer with valued pixels that we are displaying in spectral colors. Now we want to extract the contour lines and to have a color fill between those contour lines. How would you do this – is there an easy solution, which differs from the numerous tutorials on the web, which seem to be a lot more complicated than what we actually remember to have done?
> Thank you very much in advance, any answer would be very helpful!
> Best regards,
> Hannes Kohlmann
> Qgis-user mailing list
> [hidden email]
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/QGIS-help-filled-contour-lines-from-raster-layer-data-tp5284720.html
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/QGIS-help-filled-contour-lines-from-raster-layer-data-tp5284720p5284798.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160908/984d1463/attachment.html>
