[Qgis-user] QGIS resource sharing plugin crashes QGIS
    Etienne Trimaille
    etienne.trimaille at gmail.com
    Fri Sep  9 07:19:22 PDT 2016
It's a known issue with every plugins using QWebKit with Ubuntu qgis 2.16.
It seems that the latest QGIS Nightly build fixed this bug :
https://lists.osgeo.org/pipermail/qgis-developer/2016-September/044495.html
2016-09-09 12:27 GMT+02:00 Filipe Dias <filipesdias at gmail.com>:
> Hi
> I just tried to install QGIS Resource Sharing plugin but QGIS crashed.
> When I tried to restart it crashed again with this error message. Is it a
> known issue? Should I report it?
> Manually deleting the plugin solves the issue.
> Thanks
> Cheers
> Warning: loading of qgis translation failed [/usr/share/qgis/i18n//qgis_
> en_US]
> Warning: loading of qt translation failed [/usr/share/qt4/translations/
> qt_en_US]
> Warning: QCss::Parser - Failed to load file  "/style.qss"
> Warning: QLayout: Attempting to add QLayout "" to QgsPanelWidgetStack
> "mWidgetStack", which already has a layout
> Warning: QVariantMap DBusMenuExporterDBus::getProperties(int, const
> QStringList&) const: Condition failed: action
> Warning: void DBusMenuExporterPrivate::addAction(QAction*, int): Already
> tracking action "Search QMS" under id 225
> tracking action "&Toolbox" under id 361
> Warning: Object::connect: No such signal QWebPage::loadProgress(int)
> Warning: Object::connect: No such signal QWebPage::unsupportedContent(
> QNetworkReply*)
> Warning: Object::connect: No such signal QWebFrame::titleChanged(QString)
> Warning: Object::connect: No such signal QWebFrame::iconChanged()
> Warning: Object::connect: No such signal QWebFrame::urlChanged(QUrl)
> Warning: Object::connect: No such signal QWebPage::loadStarted()
> Warning: Object::connect: No such signal QWebPage::loadFinished(bool)
> Warning: Object::connect: No such signal QWebPage::statusBarMessage(
> QString)
> Warning: Object::connect: No such signal QWebPage::linkClicked(QUrl)
> Warning: Object::connect: No such signal QWebPage::selectionChanged()
> Warning: Object::connect: No such signal QWebPage::microFocusChanged()
> Warning: QMetaObject::invokeMethod: No such method
> QWebPage::repaintRequested(QRect)
> Segmentation fault (core dumped)
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160909/7062241d/attachment.html>
