[Qgis-user] QGIS resource sharing plugin crashes QGIS
Filipe Dias filipesdias at gmail.com
Fri Sep 9 03:27:53 PDT 2016
Hi
I just tried to install QGIS Resource Sharing plugin but QGIS crashed. When
I tried to restart it crashed again with this error message. Is it a known
issue? Should I report it?
Manually deleting the plugin solves the issue.
Thanks
Cheers
Warning: loading of qgis translation failed
[/usr/share/qgis/i18n//qgis_en_US]
Warning: loading of qt translation failed
[/usr/share/qt4/translations/qt_en_US]
Warning: QCss::Parser - Failed to load file  "/style.qss"
Warning: QLayout: Attempting to add QLayout "" to QgsPanelWidgetStack
"mWidgetStack", which already has a layout
Warning: QVariantMap DBusMenuExporterDBus::getProperties(int, const
QStringList&) const: Condition failed: action
Warning: void DBusMenuExporterPrivate::addAction(QAction*, int): Already
tracking action "Search QMS" under id 225
tracking action "&Toolbox" under id 361
Warning: Object::connect: No such signal QWebPage::loadProgress(int)
QWebPage::unsupportedContent(QNetworkReply*)
Warning: Object::connect: No such signal QWebFrame::titleChanged(QString)
Warning: Object::connect: No such signal QWebFrame::iconChanged()
Warning: Object::connect: No such signal QWebFrame::urlChanged(QUrl)
Warning: Object::connect: No such signal QWebPage::loadStarted()
Warning: Object::connect: No such signal QWebPage::loadFinished(bool)
Warning: Object::connect: No such signal QWebPage::statusBarMessage(QString)
Warning: Object::connect: No such signal QWebPage::linkClicked(QUrl)
Warning: Object::connect: No such signal QWebPage::selectionChanged()
Warning: Object::connect: No such signal QWebPage::microFocusChanged()
Warning: QMetaObject::invokeMethod: No such method
QWebPage::repaintRequested(QRect)
Segmentation fault (core dumped)
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160909/02567d1d/attachment.html>
