[Qgis-user] Sampling points, keeping order
    Richard McDonnell
    richard.mcdonnell at opw.ie
    Mon Sep 12 02:29:34 PDT 2016
Add an ID column, I assume the order they appear in the table is the
order they where entered in, therefore using an ID column should sort
out your problem.
Regards,
Richard.
On 12/09/2016 02:10, Carlos Cerdán wrote:
> Yes, it is!
> Thank you very much Nicolas, that was I was looking for, "add raster
> values to points" keeps ordered the attribute table of my sampling
> point collection.
> Greetings from Perú.
> Carlos
> 2016-09-11 14:36 GMT-05:00 Nicolas Cadieux
> <nicolas.cadieux at archeotec.ca <mailto:nicolas.cadieux at archeotec.ca>>:
>     Hi
>     Perhaps this could help.  It uses the processing toolbox.
>     https://pvanb.wordpress.com/2014/07/01/sampling-raster-values-at-point-locations-in-qgis-an-update/
>     <https://pvanb.wordpress.com/2014/07/01/sampling-raster-values-at-point-locations-in-qgis-an-update/>
>     Envoyé de mon iPad
>     Le 8 sept. 2016 à 18:10, Carlos Cerdán [via OSGeo.org
>     <http://osgeo.org>] <[hidden email]
>     <http:///user/SendEmail.jtp?type=node&node=5285189&i=0>> a écrit :
>>     Hi list:
>>     I have got a rasters set for montly precipitation, between 1981
>>     and 2015, with names 1981-01; 1981-02; etc. so, in a files
>>     browser, 420 files (36 years x 12 months) are showed, ordered.
>>     I also have a shape of points where I want to sampling points
>>     whit such plugin, but when I use it, fields are ordered randomly,
>>     so I'll have to use table manager plugin to order fields.
>>     Some advice about how to make it directly, keeping order? Does
>>     "point sampling tool" plugin keep order with some way to order
>>     layers in QGIS panel?
>>     As a shape file has limitations about the number of fields (255?)
>>     I have to do it in parts of 10 years. After it, i hope to join
>>     these parts in Spatialite. Is there some way to do it directly in
>>     Spatialite?
>>     Greetings
>>     Carlos Cerdán
>>     _______________________________________________
>>     Qgis-user mailing list
>>     [hidden email]
>>     <http:///user/SendEmail.jtp?type=node&node=5284851&i=0>
>>     List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>     <http://lists.osgeo.org/mailman/listinfo/qgis-user>
>>     Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>     If you reply to this email, your message will be added to the
>>     discussion below:
>>     http://osgeo-org.1560.x6.nabble.com/Sampling-points-keeping-order-tp5284851.html
>>     <http://osgeo-org.1560.x6.nabble.com/Sampling-points-keeping-order-tp5284851.html>
>>     To start a new topic under Quantum GIS - User, email [hidden
>>     email] <http:///user/SendEmail.jtp?type=node&node=5285189&i=1>
>>     To unsubscribe from Quantum GIS - User, click here.
>>     NAML
>>     <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>     View this message in context: Re: Sampling points, keeping order
>     <http://osgeo-org.1560.x6.nabble.com/Sampling-points-keeping-order-tp5284851p5285189.html>
>     Sent from the Quantum GIS - User mailing list archive
>     <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html>
>     at Nabble.com.
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
*_Richard McDonnell_*
*GIS Specialist PgD GIS AssocSCSI*
*OPW FRM Data Management*
*52 Stephens Green, Dublin 2.*
TEL: 01 6476543
OPW - Ag féachaint don am atá le teacht - Ag caomhnú ón am atá thart
OPW - Looking to the future - Caring for the past
Email Disclaimer: http://www.opw.ie/en/disclaimer/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160912/008a999c/attachment.html>
