[Qgis-user] qGIS crashes when working on rasters
    pzab
    firstgis24 at gmail.com
    Fri Sep  9 14:16:49 PDT 2016
Hi Nicolas,
In fact that's the only layer loaded to the project. I checked also when
trying to clip the raster it crashes again and I cannot even create
contours from clipped raster because it says the gdal_contour doesnt work.
And the most funny thing is that I loaded the same raster to arcgis desktop
and it worked at first time, I even create contours and then a tin from
them.
I wonder what is causing the problem.
I checked at the other project. I loaded cataster data from wms and I
create parcels.shp to digitize the data from wms. Everything works fine
until...until I loaded a raster to the project.
I did uninstall twice and installed clean 2.16 and...the problem returned.
Why it worked on arcgis and why wont work on qgis?
09.09.2016 23:01 "Nicolas Cadieux [via OSGeo.org]" <
ml-node+s1560n5285041h69 at n6.nabble.com> napisał(a):
In Qgis 2.12, I can crash it if I have to many file with different
projections across a big territory (Canada).
Turn off all layers, change the project CRS to the layer you are having
trouble with, then zoom to the layer
extent, then turn the layer back on.  That may... Or may not help..
Good luck!
Nicolas
Envoyé de mon iPad
Le 9 sept. 2016 à 15:43, pzab [via OSGeo.org <http://osgeo.org>] <[hidden
email] <http:///user/SendEmail.jtp?type=node&node=5285041&i=0>> a écrit :
[image: crash msg]
Hello,
I am new user here and I would like to ask You for a solution concerning my
problem.
So...
I downloaded and installed qGIS 2.14.6 LTR. I tried to follow this tutorial
http://www.qgistutorials.com/en/docs/working_with_terrain.html.
I got the raster, added it to my new project and when I insert the coords
for Mt. Everest and change a scale I got the message qgis-ltr-bin stopped
working. And it automatically closed qgis windows. I restarted my computer
and try it again...and I got the same message.
What can be the issue of this problem?
Thank You very much in advance for helping me out.
If you reply to this email, your message will be added to the discussion
below:
http://osgeo-org.1560.x6.nabble.com/qGIS-crashes-when-
working-on-rasters-tp5285026.html
To start a new topic under Quantum GIS - User, email [hidden email]
<http:///user/SendEmail.jtp?type=node&node=5285041&i=1>
To unsubscribe from Quantum GIS - User, click here.
NAML
<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
below:
http://osgeo-org.1560.x6.nabble.com/qGIS-crashes-when-working-on-rasters-
tp5285026p5285041.html
To unsubscribe from qGIS crashes when working on rasters, click here
<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5285026&code=Zmlyc3RnaXMyNEBnbWFpbC5jb218NTI4NTAyNnwzMzA2OTI0NTY=>
NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/qGIS-crashes-when-working-on-rasters-tp5285026p5285045.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160909/936687d1/attachment.html>
