[Qgis-user] qGIS crashes when working on rasters
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Fri Sep 9 14:21:59 PDT 2016
Do you have slink to the raster. I could test on 2.14
Envoyé de mon iPad
> Le 9 sept. 2016 à 17:16, pzab [via OSGeo.org] <ml-node+s1560n5285045h56 at n6.nabble.com> a écrit :
> Hi Nicolas,
> In fact that's the only layer loaded to the project. I checked also when trying to clip the raster it crashes again and I cannot even create contours from clipped raster because it says the gdal_contour doesnt work.
> And the most funny thing is that I loaded the same raster to arcgis desktop and it worked at first time, I even create contours and then a tin from them.
> I wonder what is causing the problem.
> I checked at the other project. I loaded cataster data from wms and I create parcels.shp to digitize the data from wms. Everything works fine until...until I loaded a raster to the project.
> I did uninstall twice and installed clean 2.16 and...the problem returned.
> Why it worked on arcgis and why wont work on qgis?
> 09.09.2016 23:01 "Nicolas Cadieux [via OSGeo.org]" <[hidden email]> napisał(a):
> Hi,
> In Qgis 2.12, I can crash it if I have to many file with different projections across a big territory (Canada).
> Turn off all layers, change the project CRS to the layer you are having trouble with, then zoom to the layer
> extent, then turn the layer back on.  That may... Or may not help..
> Good luck!
> Nicolas
> Envoyé de mon iPad
>> Le 9 sept. 2016 à 15:43, pzab [via OSGeo.org] <[hidden email]> a écrit :
>> Hello,
>> I am new user here and I would like to ask You for a solution concerning my problem.
>> So...
>> I downloaded and installed qGIS 2.14.6 LTR. I tried to follow this tutorial http://www.qgistutorials.com/en/docs/working_with_terrain.html.
>> I got the raster, added it to my new project and when I insert the coords for Mt. Everest and change a scale I got the message qgis-ltr-bin stopped working. And it automatically closed qgis windows. I restarted my computer and try it again...and I got the same message.
>> What can be the issue of this problem?
>> Thank You very much in advance for helping me out.
>> If you reply to this email, your message will be added to the discussion below:
>> http://osgeo-org.1560.x6.nabble.com/qGIS-crashes-when-working-on-rasters-tp5285026.html
>> To start a new topic under Quantum GIS - User, email [hidden email]
>> To unsubscribe from Quantum GIS - User, click here.
>> NAML
> http://osgeo-org.1560.x6.nabble.com/qGIS-crashes-when-working-on-rasters-tp5285026p5285041.html
> To unsubscribe from qGIS crashes when working on rasters, click here.
> NAML
> http://osgeo-org.1560.x6.nabble.com/qGIS-crashes-when-working-on-rasters-tp5285026p5285045.html
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/qGIS-crashes-when-working-on-rasters-tp5285026p5285046.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160909/01b38140/attachment.html>
