[Qgis-user] Orfeo Toolbox
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Sat Sep 10 07:26:54 PDT 2016
Some algorithms in the processing tool box rely on software that in not installed on Qgis. It seems that this is the case with Orfeo toolbox.
First, find and install the software on the net.  Orfeo Toolbox is open source.  Then, click on the processing menu in Qgis and you will see the options (settings, options, or configuration (I am not in front of a screen)) to set the directory of the binaries (normally the .exe file).   Once this is done, you will be able to use the toolbox.  Close and reopen this directory screen to make sure it saved the directory properly.
You can also do that in Qgis without Orfeo (but Orfeo is very good).   In the Qgis raster menu, you will find the gdal translate function.  Select the input file,  the output file and the rest of the options.  You will see on the bottom of the window the gdal script that is modified as you fill in the options.  Then click on the small yellow pencil and then finally on the help button.  That will bring you to a web page where you can see options that are not in the Qgis gui.  Add the -b switch to the script.  If you add "-b 4" (no quotes) you will save band 4 only.  See.
gis.stackexchange.com/questions/62133/how-to-export-only-one-band-from-an-image-using-gdal
I Imagine you can also do this in the processing toolbox.  If you right click on the algorithm , you will see the option to script the function multiple times.  This way, you can set the scripts so that, if you have 10 bands, you can set all 10 output files. That will save you time. There should be a space where you can add additional switches.  Add the -b 1 in the there then -b 2 for the next file...  Once you have set up everything, Qgis will save all the files in one shot.
Good luck
Nicolas
Envoyé de mon iPad
> Le 10 sept. 2016 à 01:42, Geraud C. Tasse [via OSGeo.org] <ml-node+s1560n5285067h38 at n6.nabble.com> a écrit :
> Dear all,
> I am using QGIS 2.16.2 and wish to split a multiband image into individual raster. In the Orfeo Toolbox I can see the algorithm split image but when I want to select it I keep receiving an error message:  Missing dependency. This algorithm cannot be run :-(
> OTB folder is not configured. Please configure it before running OTB algorithms.
> Could someone tell me how to configure it?
> Thanks
> Geraud
> Qgis-user mailing list
> [hidden email]
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/Orfeo-Toolbox-tp5285067.html
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Orfeo-Toolbox-tp5285067p5285098.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160910/999aa814/attachment.html>
