[Qgis-user] Question about the translate tool (under raster) - ADRG driver error
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Sun Sep 11 08:30:47 PDT 2016
To my knowledge, tiff has always been my default unless specified. Perhaps that in 2.16, the default relies on a different variable (like a previously saved format)? Not sure. I any case, this has permitted you to discover the help button with all the different switches that are not in the Qgis GUI. It would be nice to expand the QGis GUI but that would require that it be continually upgraded with the gdal switches. But the help button and little yellow pencil icon with always be superior and more flexible then an expanded GUI.
The error is normal if the format (ADRG) does not support multiple bands. I don't know that format but I get a similar error if I try to save a RGB image as a .DEM by mistake. .dem, of course, only handles one single band, or one layer of data. (The result is a grey image).
Nicolas
Envoyé de mon iPad
> Le 11 sept. 2016 à 01:43, Laurence Béchet [via OSGeo.org] <ml-node+s1560n5285143h94 at n6.nabble.com> a écrit :
> Hi,
> While I was trying to convert a (tiff + world file) into a geo referenced tiff with the translate tool, I got the following error:
> error 6 : ADRG driver doesn't support 4 bands (etc)
> After searching on the web (unsuccessfully) I finally noticed that the command line auto completed itself with -of ADRG while it should be -of GTiff (following the help advices).
> I manually changed it and it worked.
> Is it normal?
> Windows 8.1 64b
> QGIS 2.16.2 Code revision 979e1a2
> Thanks
> Laurence
> ARK IN THE PARK Volunteer Co-Ordinator
> Cascades Ranger Station
> Falls Road, Waitākere
> Qgis-user mailing list
> [hidden email]
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/Question-about-the-translate-tool-under-raster-ADRG-driver-error-tp5285143.html
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Question-about-the-translate-tool-under-raster-ADRG-driver-error-tp5285143p5285166.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160911/a6a056ab/attachment.html>
