[Qgis-user] Working with old Arc/Info coverage
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Tue Sep 13 17:00:17 PDT 2016
Could it be EPSG 2163?
http://gis.stackexchange.com/questions/113980/custom-projection-problem-with-proj-4
Use a background to see if that's it. You can use the open layer plugin. Be careful, that plugin will change the project CRS. You can change it back or you can make sure "crs on the fly " is activated.
If that is not it. Right click on the layer and redefine the layer CRS, then zoom to extent.
Nicolas
Envoyé de mon iPad
> Le 13 sept. 2016 à 19:25, Frank Reichenbacher [via OSGeo.org] <ml-node+s1560n5285694h75 at n6.nabble.com> a écrit :
> What CRS in Qgis project properties should I select in order to work with an Arc/Info binary coverage?
> A readme file in the coverage says this:
> COORDINATE SYSTEM DESCRIPTION
> Projection LAMBERT_AZIMUTHAL
> Datum NAD83
> Units METERS Spheroid DEFINED
> Major Axis 6370997.00000 Minor Axis 0.00000
> Parameters:
> radius of the sphere of reference 6370997.00000
> longitude of center of projection -100 0 0.00
> latitude of center of projection 45 0 0.000
> false easting (meters) 0.00000
> false northing (meters) 0.00000
> Yes, I am a newbie!
> Frank Reichenbacher
> Scottsdale, Arizona
> Qgis-user mailing list
> [hidden email]
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/Working-with-old-Arc-Info-coverage-tp5285694.html
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Working-with-old-Arc-Info-coverage-tp5285694p5285698.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160913/9168e12a/attachment.html>
