[Qgis-user] Working with old Arc/Info coverage
Frank Reichenbacher
frank at alamocito.com
Tue Sep 13 17:16:04 PDT 2016
Très bon! You had it exactly right. Thank you!
Frank
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Nicolas Cadieux
Sent: Tuesday, September 13, 2016 5:00 PM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Working with old Arc/Info coverage
Could it be EPSG 2163?
http://gis.stackexchange.com/questions/113980/custom-projection-problem-with-proj-4
Use a background to see if that's it. You can use the open layer plugin. Be careful, that plugin will change the project CRS. You can change it back or you can make sure "crs on the fly " is activated.
If that is not it. Right click on the layer and redefine the layer CRS, then zoom to extent.
Nicolas
Envoyé de mon iPad
Le 13 sept. 2016 à 19:25, Frank Reichenbacher [via OSGeo.org <http://osgeo.org> ] <[hidden email]> a écrit :
What CRS in Qgis project properties should I select in order to work with an Arc/Info binary coverage?
A readme file in the coverage says this:
COORDINATE SYSTEM DESCRIPTION
Projection LAMBERT_AZIMUTHAL
Datum NAD83
Units METERS Spheroid DEFINED
Major Axis 6370997.00000 Minor Axis 0.00000
Parameters:
radius of the sphere of reference 6370997.00000
longitude of center of projection -100 0 0.00
latitude of center of projection 45 0 0.000
false easting (meters) 0.00000
false northing (meters) 0.00000
Yes, I am a newbie!
Frank Reichenbacher
Scottsdale, Arizona
Qgis-user mailing list
[hidden email]
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
_____
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Working-with-old-Arc-Info-coverage-tp5285694.html
To start a new topic under Quantum GIS - User, email [hidden email]
To unsubscribe from Quantum GIS - User, click here.
<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml> NAML
_____
View this message in context: Re: Working with old Arc/Info coverage <http://osgeo-org.1560.x6.nabble.com/Working-with-old-Arc-Info-coverage-tp5285694p5285698.html>
Sent from the Quantum GIS - User mailing list archive <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html> at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160913/38ddbb21/attachment.html>
