[Qgis-user] Working with old Arc/Info coverage
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Tue Sep 13 17:22:33 PDT 2016
Educated guess... :)
Bonne soirée!
Nicolas
Envoyé de mon iPad
> Le 13 sept. 2016 à 20:16, Frank Reichenbacher [via OSGeo.org] <ml-node+s1560n5285699h30 at n6.nabble.com> a écrit :
> Très bon! You had it exactly right. Thank you!
> Frank
> From: Qgis-user [mailto:[hidden email]] On Behalf Of Nicolas Cadieux
> Sent: Tuesday, September 13, 2016 5:00 PM
> To: [hidden email]
> Subject: Re: [Qgis-user] Working with old Arc/Info coverage
> Hi,
> Could it be EPSG 2163?
> http://gis.stackexchange.com/questions/113980/custom-projection-problem-with-proj-4
> Use a background to see if that's it.  You can use the open layer plugin. Be careful, that plugin will change the project CRS.  You can change it back or you can make sure "crs on the fly " is activated.
> If that is not it.  Right click on the layer and redefine the layer CRS, then zoom to extent.
> Nicolas
> Envoyé de mon iPad
> Le 13 sept. 2016 à 19:25, Frank Reichenbacher [via OSGeo.org] <[hidden email]> a écrit :
> What CRS in Qgis project properties should I select in order to work with an Arc/Info binary coverage?
> A readme file in the coverage says this:
>                           COORDINATE SYSTEM DESCRIPTION
> Projection    LAMBERT_AZIMUTHAL
> Datum                     NAD83
> Units                    METERS             Spheroid         DEFINED
> Major Axis        6370997.00000             Minor Axis       0.00000
> Parameters:
> radius of the sphere of reference                      6370997.00000
> longitude of center of projection                      -100  0  0.00
> latitude of center of projection                        45  0  0.000
> false easting (meters)                                       0.00000
> false northing (meters)                                      0.00000
> Yes, I am a newbie!
> Frank Reichenbacher
> Scottsdale, Arizona
> Qgis-user mailing list
> [hidden email]
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/Working-with-old-Arc-Info-coverage-tp5285694.html
> To start a new topic under Quantum GIS - User, email [hidden email]
> To unsubscribe from Quantum GIS - User, click here.
> NAML
> View this message in context: Re: Working with old Arc/Info coverage
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> [hidden email]
> http://osgeo-org.1560.x6.nabble.com/Working-with-old-Arc-Info-coverage-tp5285694p5285699.html
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Working-with-old-Arc-Info-coverage-tp5285694p5285700.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160913/7e392ed2/attachment.html>
