[Qgis-user] Map composer. Wrong map scale
Nicolas Cadieux nicolas.cadieux at archeotec.ca
Wed Sep 14 05:02:21 PDT 2016
Could the scale be tied to an different object or a hidden map window in your layout?  If so, it could be giving you a scale for a different map window.
Nicolas
Envoyé de mon iPad
> Le 14 sept. 2016 à 04:20, Carlo Cormio [via OSGeo.org] <ml-node+s1560n5285755h66 at n6.nabble.com> a écrit :
> No, I'm using QuickMapServices plugin
> Il 14/09/2016 09:39, Nyall Dawson ha scritto:
> > On 14 September 2016 at 17:32, Carlo Cormio <[hidden email]> wrote:
> >> Dear all,
> >> I'm using QGIS 2.12.3 on Windows 10. After printing a map using QGIS map
> >> composer, I checked some distances and found that map scale was different
> >> from the expected one.
> >> I set ISO A3, portrait, as page size. QGIS project has EPSG:3857 (due to the
> >> use of a google satellite layer), but most of the other layers have
> >> EPSG:32633. I tell you this in case it could affect prints.
> >> Map scale in print composer was set to 1:5000, but when I measured distances
> >> (I also put a scale in the composition) I found it was more or less 1:3500.
> >> The strange thing is that the ratio between the two scales is 1,41, that is
> >> exactly ISO A3:A4 ratio.
> >> What did I do wrong? Is there a setting I missed?
> > Are you using the OpenLayers plugin?
> > Nyall
> >> Hope I gave all the necessary information.
> >> Regards,
> >> Carlo
> >> _______________________________________________
> >> Qgis-user mailing list
> >> [hidden email]
> >> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> [hidden email]
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/Map-composer-Wrong-map-scale-tp5285744p5285755.html
> To start a new topic under Quantum GIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from Quantum GIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Map-composer-Wrong-map-scale-tp5285744p5285827.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160914/b261b9c9/attachment.html>
