[Qgis-user] Map composer. Wrong map scale
Carlo Cormio
carlo.cormio at gmail.com
Wed Sep 14 07:15:27 PDT 2016
Hi Nicolas,
I checked and the scale is referred to the right map window. I have
several pages in the same composer, and all maps have the same scale factor.
Carlo
Il 14/09/2016 14:02, Nicolas Cadieux ha scritto:
> Hi,
> Could the scale be tied to an different object or a hidden map window
> in your layout? If so, it could be giving you a scale for a different
> map window.
> Nicolas
> Envoyé de mon iPad
> Le 14 sept. 2016 à 04:20, Carlo Cormio [via OSGeo.org
> <http://osgeo.org>] <[hidden email]
> </user/SendEmail.jtp?type=node&node=5285827&i=0>> a écrit :
>> No, I'm using QuickMapServices plugin
>> Il 14/09/2016 09:39, Nyall Dawson ha scritto:
>> > On 14 September 2016 at 17:32, Carlo Cormio <[hidden email]
>> </user/SendEmail.jtp?type=node&node=5285755&i=0>> wrote:
>> >> Dear all,
>> >> I'm using QGIS 2.12.3 on Windows 10. After printing a map using
>> QGIS map
>> >> composer, I checked some distances and found that map scale was
>> different
>> >> from the expected one.
>> >> I set ISO A3, portrait, as page size. QGIS project has EPSG:3857
>> (due to the
>> >> use of a google satellite layer), but most of the other layers have
>> >> EPSG:32633. I tell you this in case it could affect prints.
>> >> Map scale in print composer was set to 1:5000, but when I measured
>> distances
>> >> (I also put a scale in the composition) I found it was more or
>> less 1:3500.
>> >> The strange thing is that the ratio between the two scales is
>> 1,41, that is
>> >> exactly ISO A3:A4 ratio.
>> >> What did I do wrong? Is there a setting I missed?
>> > Are you using the OpenLayers plugin?
>> > Nyall
>> >> Hope I gave all the necessary information.
>> >> Regards,
>> >> Carlo
>> >> _______________________________________________
>> >> Qgis-user mailing list
>> >> [hidden email] </user/SendEmail.jtp?type=node&node=5285755&i=1>
>> >> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> >> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> [hidden email] </user/SendEmail.jtp?type=node&node=5285755&i=2>
>> If you reply to this email, your message will be added to the
>> discussion below:
>> http://osgeo-org.1560.x6.nabble.com/Map-composer-Wrong-map-scale-tp5285744p5285755.html
>> To start a new topic under Quantum GIS - User, email [hidden email]
>> </user/SendEmail.jtp?type=node&node=5285827&i=1>
>> To unsubscribe from Quantum GIS - User, click here.
>> NAML
>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: Re: Map composer. Wrong map scale
> <http://osgeo-org.1560.x6.nabble.com/Map-composer-Wrong-map-scale-tp5285744p5285827.html>
> Sent from the Quantum GIS - User mailing list archive
> <http://osgeo-org.1560.x6.nabble.com/Quantum-GIS-User-f4125267.html>
> at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160914/3a8ccb7b/attachment.html>
