[Qgis-user] qgsRelationReferenceWidget
Tyler Veinot tylerkveinot at gmail.com
Fri Sep 16 03:44:30 PDT 2016
Andrew;
Well that was simple, thank you. I didn't even think to look there; I was
trying to add a standard push button and associate it with save.
Now I just have to solve everything else.
Thanks again.
Tyler
On Thu, Sep 15, 2016 at 4:22 PM, Andrew <amcaninch at gmail.com> wrote:
> Regarding your second question, in QTDesigner you can change the default
> buttonBox properties to include a "Save" or "Apply" button.
> On Thu, Sep 15, 2016 at 8:17 AM, Tyler Veinot <tylerkveinot at gmail.com>
> wrote:
>> Not having much luck with this, I managed to get the
>> qgsRelationReferenceWidget to show me a list of addresses but I cannot get
>> it to write the wo_id and unique_id to my table.
>> On a different note, is there an ability to create a "save"? the "ok"
>> button closes the form completely. I just want to "save" my work order to
>> write its values to the wo_table and continue editing.
>> Tyler
>> On Tue, Sep 13, 2016 at 9:35 AM, Tyler Veinot <tylerkveinot at gmail.com>
>> wrote:
>>> Matthias;
>>> Ooop's I forgot to add that I was building the form in Qt Designer and
>>> not from within QGIS, although with this information is really good and is
>>> showing me things I didn't quite understand before. I am a very visual
>>> person I find it hard to understand things without seeing it in a diagram
>>> or some other example. Took me forever to figure out dog gears and
>>> differential gears until I tore apart my first bicycle and rear end; as
>>> soon as I seen it I got it.
>>> This is my relationship defined in QGIS thus far....
>>> When I add an address to the work order I need to write the wo_id of my
>>> work order and my unique_id of my address to my jtbl_cwo table. So when I,
>>> or someone, opens a work order it will show them a list of address
>>> associated to that one work order. Also need to do the same thing with
>>> primary assets, so the form will look something like this in QGIS;
>>> ​Of course the unique_id will be referencing a value from the
>>> civic_points "address" but that is that I am trying to accomplish. I did it
>>> in LibreOffice and Access but I would like to consolidate it all into one
>>> database with one interface, i.e. QGIS. That way I can edit features, add
>>> assets, and do most of my daily tasks in one application.
>>> Is there an example of this being done in QGIS anywhere?
>>> Tyler
>>> On Tue, Sep 13, 2016 at 8:37 AM, Tyler Veinot <tylerkveinot at gmail.com>
>>> wrote:
>>>> Matthias;
>>>> Thanks, I don't know what I would do without you! Coding isn't normally
>>>> an issue but that tutorial didn't quite explain where to put the coding.
>>>> When I opened the UI file in IDLE it looked like XML, and there were no
>>>> other files associated with the form. I also opened the "see code" option
>>>> and it was the same looked like XML; it might have been C++ but I have no
>>>> training or experience with C++ so I wouldn't know if it looked similar to
>>>> XML from the "untrained eye" point of view.
>>>> Going to be doing some testing on the versioning bit here this week,
>>>> hope to have something a little more concrete to say about it soon.
>>>> Tyler
>>>> On Tue, Sep 13, 2016 at 2:58 AM, Matthias Kuhn <matthias at opengis.ch>
>>>> wrote:
>>>>> Hi Tyler,
>>>>> Here is the blog post I wrote for this feature:
>>>>> http://blog.vitu.ch/10112013-1201/qgis-relations
>>>>> Just configuration, no coding, I hope that helps.
>>>>> Cheers
>>>>> Matthias
>>>>> On 12/09/16 22:56, Tyler Veinot wrote:
>>>>> All;
>>>>> Trying to make a form for QGIS that has a form within a form so that I
>>>>> can link and display entries from another table similar to this tuorial;
>>>>> https://medspx.fr/blog/Qgis/better_qgis_forms_part_three/
>>>>> I think I need to use qgsValueRelationRefernceWidget but I cannot find
>>>>> any tutorials on it.
>>>>> Thanks;
>>>>> Tyler
>>>>> _______________________________________________
>>>>> Qgis-user mailing listQgis-user at lists.osgeo.org
>>>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160916/9ff668db/attachment.html>
