[Qgis-user] Problem with GRASS commands
Alexandre Neto
senhor.neto at gmail.com
Mon Sep 19 00:29:06 PDT 2016
Did you installed QGIS using OSGeo4w or standalone?
In the processing option, providers, make sure GRASS 7 path is pointing to
the correct folder. And disable GRASS (6).
I seen some installations where grass 7 was pointing to an old grass
installation
A seg, 19/09/2016, 08:07, Grant Boxer <boxerg at iinet.net.au> escreveu:
> Hi Alexandre,
> I am using Windows 7 64-bit OS.
> Regards Grant
> *From:* Alexandre Neto [mailto:senhor.neto at gmail.com]
> *Sent:* Monday, 19 September 2016 2:59 PM
> *To:* Grant Boxer; qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Problem with GRASS commands
> What is your operating system? That will help solving the problem.
> A seg, 19/09/2016, 05:04, Grant Boxer <boxerg at iinet.net.au> escreveu:
> I am trying to run GRASS commands in QGIS 2.14 (LTR) and I get the
> following message, “*Missing dependency. This algorithm cannot be run :-(
> *It seems that GRASS is not correctly installed and configured in your
> system. Please install it before running GRASS algorithms.”
> Any suggestions?
> Grant Boxer
> Perth, Western Australia
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
Alexandre Neto
@AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160919/d4d07258/attachment.html>
