[Qgis-user] Problem with GRASS commands
Nikolaus Pruzsinszky
n.pru at reflex.at
Tue Sep 20 23:32:10 PDT 2016
I am facing the same problem since 2.12 (including 2.16). Standalone
Installer, Win7 64 bit.
I did the adjustments in the processing options, no improvement.
Anyone got any idea?
Best regards,
Niko
> *Did you installed QGIS using OSGeo4w or standalone?
> In the processing option, providers, make sure GRASS 7 path is pointing to
> the correct folder. And disable GRASS (6).
> I seen some installations where grass 7 was pointing to an old grass
> installation
> A seg, 19/09/2016, 08:07, Grant Boxer <boxerg at iinet.net.au <http://lists.osgeo.org/mailman/listinfo/qgis-user>> escreveu:
> > Hi Alexandre,
> > I am using Windows 7 64-bit OS.
> > Regards Grant
> > *From:* Alexandre Neto [mailto:senhor.neto at gmail.com <http://lists.osgeo.org/mailman/listinfo/qgis-user>]
> > *Sent:* Monday, 19 September 2016 2:59 PM
> > *To:* Grant Boxer; qgis-user at lists.osgeo.org <http://lists.osgeo.org/mailman/listinfo/qgis-user>
> > *Subject:* Re: [Qgis-user] Problem with GRASS commands
> > What is your operating system? That will help solving the problem.
> > A seg, 19/09/2016, 05:04, Grant Boxer <boxerg at iinet.net.au <http://lists.osgeo.org/mailman/listinfo/qgis-user>> escreveu:
> > I am trying to run GRASS commands in QGIS 2.14 (LTR) and I get the
> > following message, “*Missing dependency. This algorithm cannot be run :-(
> > *It seems that GRASS is not correctly installed and configured in your
> > system. Please install it before running GRASS algorithms.”
> > Any suggestions?
> > Grant Boxer
> > Perth, Western Australia
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org <http://lists.osgeo.org/mailman/listinfo/qgis-user>
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user <http://lists.osgeo.org/mailman/listinfo/qgis-user>
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user <http://lists.osgeo.org/mailman/listinfo/qgis-user>
> > Alexandre Neto
> > @AlexNetoGeo
> > http://sigsemgrilhetas.wordpress.com <http://sigsemgrilhetas.wordpress.com>
> > http://gisunchained.wordpress.com <http://gisunchained.wordpress.com>
> Alexandre Neto
> @AlexNetoGeo
> **http://gisunchained.wordpre*ss.com <http://gisunchained.wordpress.com>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160921/348e9391/attachment.html>
