[Qgis-user] Problem with GRASS commands
teddy guerin teddyguerin at yahoo.fr
Wed Sep 21 00:53:48 PDT 2016
Hello,
I found this QGis 2.14 et Grass 7: comment faire? | Blog SIG & Territoires ---- Le blog SIG pour la gestion territoriale
QGis 2.14 et Grass 7: comment faire? | Blog SIG & Territoires ---- Le b...
 Depuis la version 2.14 de QGis, quelle qu'elle soit l'installation choisie, il est devenu impossible d&#...  |
 I apologize but this link is in french ;-)
Best regardsTed
      De : Nikolaus Pruzsinszky <n.pru at reflex.at>
 À : qgis-user at lists.osgeo.org
 Envoyé le : Mercredi 21 septembre 2016 8h32
 Objet : [Qgis-user] Problem with GRASS commands
I am facing the same problem since 2.12 (including 2.16). Standalone Installer, Win7 64 bit.
I did the adjustments in the processing options, no improvement.
Anyone got any idea?
Best regards,
Niko
Did you installed QGIS using OSGeo4w or standalone?
In the processing option, providers, make sure GRASS 7 path is pointing to
the correct folder. And disable GRASS (6).
I seen some installations where grass 7 was pointing to an old grass
installation
A seg, 19/09/2016, 08:07, Grant Boxer <boxerg at iinet.net.au> escreveu:
> Hi Alexandre,
> I am using Windows 7 64-bit OS.
> Regards Grant
> *From:* Alexandre Neto [mailto:senhor.neto at gmail.com]
> *Sent:* Monday, 19 September 2016 2:59 PM
> *To:* Grant Boxer; qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Problem with GRASS commands
> What is your operating system? That will help solving the problem.
> A seg, 19/09/2016, 05:04, Grant Boxer <boxerg at iinet.net.au> escreveu:
> I am trying to run GRASS commands in QGIS 2.14 (LTR) and I get the
> following message, “*Missing dependency. This algorithm cannot be run :-(
> *It seems that GRASS is not correctly installed and configured in your
> system. Please install it before running GRASS algorithms.”
> Any suggestions?
> Grant Boxer
> Perth, Western Australia
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
Alexandre Neto
@AlexNetoGeo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160921/0437973a/attachment.html>
