[Qgis-user] Profile section digitising
Neumann, Andreas
a.neumann at carto.net
Mon Sep 19 03:56:45 PDT 2016
There is a nice profile tool in the plugin called "VoGIS-ProfilTool". It
is really flexible regarding your input data (new temporary line, line
from existing layers), vertex options and output options and it allows
to intersect with a surface layer (e.g. landcover, though this did not
work in my tests). It can handle multiple surfaces, but only creates
lines, no filled areas between the surfaces.
I suggest, if you consider writing a new tool, that you would have a
look at the "VoGIS-ProfilTool" to either get a head start and improve on
it.
Greetings,
Andreas
On 2016-09-13 08:10, Vincent Picavet (ml) wrote:
> Hi Lester,
> On 12/09/2016 15:49, Lester Anderson wrote:
>> I was wondering if anyone had advice or ideas about digitising profile
>> data (say on a geological cross-section) that is referenced to a
>> polyline in the project,
> We at Oslandia are currently developping just that.
> It will be available later this year or january 2017 at the latest.
> Please be a bit patient.
> Do not hesitate to ask if you want further information, Vincent Mora
> will be able to answer your questions.
> Regards,
> Vincent
>> Thanks
>> Lester
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160919/57afd958/attachment.html>
