[Qgis-user] Profile section digitising
Régis Haubourg regis.haubourg at gmail.com
Mon Sep 19 05:37:58 PDT 2016
Hi Andreas,
VOGIS is really nice regarding graphing profiles from surface elevation
datasets.
The use case here is  for viewing and editing profiles against 3D vector
data, not raster, such as water pipes for instance or geological data.
We chose to use a Canvas with all its power for styling and editing.
We think that we could head toward something in core in 3.0 for handling z
data, and merge raster samping over section lines, compared with 3D values
stored in vertex.
That would also be something really inline with multimap canvas proposal.
You can check public plugin prototype by vincent Mora here:
https://github.com/vmora/qgis_section
Cheers
Régis
Oslandia
regis.haubourg at oslandia.com
2016-09-19 12:56 GMT+02:00 Neumann, Andreas <a.neumann at carto.net>:
> Hi,
> There is a nice profile tool in the plugin called "VoGIS-ProfilTool". It
> is really flexible regarding your input data (new temporary line, line from
> existing layers), vertex options and output options and it allows to
> intersect with a surface layer (e.g. landcover, though this did not work in
> my tests). It can handle multiple surfaces, but only creates lines, no
> filled areas between the surfaces.
> I suggest, if you consider writing a new tool, that you would have a look
> at the "VoGIS-ProfilTool" to either get a head start and improve on it.
> Greetings,
> Andreas
> On 2016-09-13 08:10, Vincent Picavet (ml) wrote:
> Hi Lester,
> On 12/09/2016 15:49, Lester Anderson wrote:
> I was wondering if anyone had advice or ideas about digitising profile
> data (say on a geological cross-section) that is referenced to a
> polyline in the project,
> We at Oslandia are currently developping just that.
> It will be available later this year or january 2017 at the latest.
> Please be a bit patient.
> Do not hesitate to ask if you want further information, Vincent Mora
> will be able to answer your questions.
> Regards,
> Vincent
> Thanks
> Lester
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160919/1ba2b7c4/attachment.html>
