[Qgis-user] lines normal to a curve at defined points
Neumann, Andreas a.neumann at carto.net
Mon Sep 19 04:25:22 PDT 2016
Hi Danilo,
Have you looked at "marker lines"? Markers are auto-rotated to be
perpendicular to a certain point along a line. They can be placed at
vertices or at regular interval (defined distance). The combination of a
simple marker (line symbol) and line offsets should do the trick.
Hope this helps.
Andreas
On 2016-09-19 12:26, Danilo Procaccini wrote:
> Hi,
> there is a method (or a plugin) that can draw lines normal to a curve (shapefile) at defined distance (points) over the same?
> Regards,
> Danilo
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160919/e051bf19/attachment.html>
