[Qgis-user] lines normal to a curve at defined points
gam17 at riseup.net
gam17 at riseup.net
Sat Sep 24 02:23:43 PDT 2016
You can try QAD plugin. First you have to draw a line at the start point
of your curve using perpendicular snap mode than try the "arraypath"
command.
> Hi Danilo,
> Have you looked at "marker lines"? Markers are auto-rotated to be
> perpendicular to a certain point along a line. They can be placed at
> vertices or at regular interval (defined distance). The combination of
> a
> simple marker (line symbol) and line offsets should do the trick.
> Hope this helps.
> Andreas
> On 2016-09-19 12:26, Danilo Procaccini wrote:
>> Hi,
>> there is a method (or a plugin) that can draw lines normal to a curve
>> (shapefile) at defined distance (points) over the same?
>> Regards,
>> Danilo
>> Qgis-user mailing list
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
