[Qgis-user] Export form UI
Tyler Veinot
tylerkveinot at gmail.com
Mon Sep 19 05:23:42 PDT 2016
Matthias;
1000 words....
[image: Inline image 1]
I think you can see how the relationship interface is "squashed" here, the
picture is kind of small, but the "fk_wo_id" field name is cut off at the
bottom, the drop down is also very narrow. This was done in the dnd and not
the designer.
Tyler
On Mon, Sep 19, 2016 at 8:45 AM, Matthias Kuhn <matthias at opengis.ch> wrote:
> Not sure what exactly you mean?
> On 09/19/2016 01:42 PM, Tyler Veinot wrote:
> > Matthias;
> > Thanks for the info, that is disappointing but at least I know I can
> > stop looking. When I use the drag and drop for some reason when I drop a
> > relationship into the dnd I get a squashed ui for it. Not sure why that
> > is happening, or how to fix it.
> > Have you or anyone else experienced that issue?
> > Tyler
> > On Mon, Sep 19, 2016 at 8:28 AM, Matthias Kuhn <matthias at opengis.ch
> > <mailto:matthias at opengis.ch>> wrote:
> > Tyler,
> > Nope, the two are incompatible. If possible, stick to dnd. There are
> > things (search forms, multi edit...) that are incompatible with ui.
> > Matthias
> > On 09/19/2016 01:23 PM, Tyler Veinot wrote:
> > > All;
> > > Is there a way to export a form created in the "drag and drop" form
> > > editor in QGIS to a ui file for editing?
> > > I got something nearly working I have been working on for a while
> > and I
> > > would like to edit it in the Designer.
> > > Tyler
> > > _______________________________________________
> > > Qgis-user mailing list
> > > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> > > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> > <http://lists.osgeo.org/mailman/listinfo/qgis-user>
> > > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160919/904ce744/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160919/904ce744/attachment.png>
