[Qgis-user] Export form UI
    Matthias Kuhn
    matthias at opengis.ch
    Mon Sep 19 05:42:10 PDT 2016
How did you get the drag and drop designer to add the Apply, Reset etc.
buttons?
On 09/19/2016 02:23 PM, Tyler Veinot wrote:
> Matthias;
> 1000 words....
> Inline image 1
> I think you can see how the relationship interface is "squashed" here,
> the picture is kind of small, but the "fk_wo_id" field name is cut off
> at the bottom, the drop down is also very narrow. This was done in the
> dnd and not the designer.
> Tyler
> On Mon, Sep 19, 2016 at 8:45 AM, Matthias Kuhn <matthias at opengis.ch
> <mailto:matthias at opengis.ch>> wrote:
>     Not sure what exactly you mean?
>     On 09/19/2016 01:42 PM, Tyler Veinot wrote:
>     > Matthias;
>     > Thanks for the info, that is disappointing but at least I know I can
>     > stop looking. When I use the drag and drop for some reason when I drop a
>     > relationship into the dnd I get a squashed ui for it. Not sure why that
>     > is happening, or how to fix it.
>     > Have you or anyone else experienced that issue?
>     > Tyler
>     > On Mon, Sep 19, 2016 at 8:28 AM, Matthias Kuhn <matthias at opengis.ch <mailto:matthias at opengis.ch>
>     > <mailto:matthias at opengis.ch <mailto:matthias at opengis.ch>>> wrote:
>     >     Tyler,
>     >     Nope, the two are incompatible. If possible, stick to dnd. There are
>     >     things (search forms, multi edit...) that are incompatible with ui.
>     >     Matthias
>     >     On 09/19/2016 01:23 PM, Tyler Veinot wrote:
>     >     > All;
>     >     > Is there a way to export a form created in the "drag and drop" form
>     >     > editor in QGIS to a ui file for editing?
>     >     > I got something nearly working I have been working on for a while
>     >     and I
>     >     > would like to edit it in the Designer.
>     >     > Tyler
>     >     > _______________________________________________
>     >     > Qgis-user mailing list
>     >     > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     <mailto:Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>>
>     >     > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
>     <http://lists.osgeo.org/mailman/listinfo/qgis-user>
>     <http://lists.osgeo.org/mailman/listinfo/qgis-user>>
>     >     > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
