[Qgis-user] Export form UI
Tyler Veinot tylerkveinot at gmail.com
Mon Sep 19 06:38:18 PDT 2016
Matthias;
I forgot to change it back to the drag and drop ui before screen capturing
the picture, after changing it back to the dnd the size is normal and I
cannot recreate the issue. So either it corrected itself or I was using a
ui from a file when I thought I was using dnd.
Likely I didn't realize I was still in the ui file.
Tyler
On Mon, Sep 19, 2016 at 9:42 AM, Matthias Kuhn <matthias at opengis.ch> wrote:
> How did you get the drag and drop designer to add the Apply, Reset etc.
> buttons?
> On 09/19/2016 02:23 PM, Tyler Veinot wrote:
> > Matthias;
> > 1000 words....
> > Inline image 1
> > I think you can see how the relationship interface is "squashed" here,
> > the picture is kind of small, but the "fk_wo_id" field name is cut off
> > at the bottom, the drop down is also very narrow. This was done in the
> > dnd and not the designer.
> > Tyler
> > On Mon, Sep 19, 2016 at 8:45 AM, Matthias Kuhn <matthias at opengis.ch
> > <mailto:matthias at opengis.ch>> wrote:
> >     Not sure what exactly you mean?
> >     On 09/19/2016 01:42 PM, Tyler Veinot wrote:
> >     > Matthias;
> >     > Thanks for the info, that is disappointing but at least I know I
> can
> >     > stop looking. When I use the drag and drop for some reason when I
> drop a
> >     > relationship into the dnd I get a squashed ui for it. Not sure why
> that
> >     > is happening, or how to fix it.
> >     > Have you or anyone else experienced that issue?
> >     > Tyler
> >     > On Mon, Sep 19, 2016 at 8:28 AM, Matthias Kuhn <
> matthias at opengis.ch <mailto:matthias at opengis.ch>
> >     > <mailto:matthias at opengis.ch <mailto:matthias at opengis.ch>>> wrote:
> >     >     Tyler,
> >     >     Nope, the two are incompatible. If possible, stick to dnd.
> There are
> >     >     things (search forms, multi edit...) that are incompatible
> with ui.
> >     >     Matthias
> >     >     On 09/19/2016 01:23 PM, Tyler Veinot wrote:
> >     >     > All;
> >     >     > Is there a way to export a form created in the "drag and
> drop" form
> >     >     > editor in QGIS to a ui file for editing?
> >     >     > I got something nearly working I have been working on for a
> while
> >     >     and I
> >     >     > would like to edit it in the Designer.
> >     >     > Tyler
> >     >     > _______________________________________________
> >     >     > Qgis-user mailing list
> >     >     > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> >     <mailto:Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org
> >     >     > List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> >     <http://lists.osgeo.org/mailman/listinfo/qgis-user>
> >     <http://lists.osgeo.org/mailman/listinfo/qgis-user>>
> >     >     > Unsubscribe: http://lists.osgeo.org/
> >     >     Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160919/b572ceea/attachment.html>
