[Qgis-user] QField
    Matthias Kuhn
    matthias at opengis.ch
    Thu Sep 22 00:56:56 PDT 2016
QField does not (yet) support tiff with jpeg compression.
See:
http://www.qfield.org/docs/project-management/dataformat.html#raster-data
GeoPackage worked quite nice in our experience and can also be built in different resolutions (same page further down).
Matthias
On 09/22/2016 09:37 AM, Neumann, Andreas wrote:
> Hi Reginald,
> You can use the JPEG compression inside Geotiff. Note that this can be
> specified separately for both the full resolution and the pyramids. You
> can also select the compression factor to decrease the file size in
> trade off with quality.
> See
> also http://www.gdal.org/frmt_gtiff.html and http://www.gdal.org/gdaladdo.html for
> details.
> I believe that modern QGIS versions have these options exposed in the
> GUI, but probably not as default.
> So maybe there is room for potential to get a smaller size Geotiff.
> Greetings,
> Andreas
> On 2016-09-22 09:32, Reginald Carlier wrote:
> > Thanks Andreas,
> > Creating a Geotiff with pyramids did the trick. The only disadvantage
> > is that it created a file of about 1.7 GB (the original was 90 MB).
> > Now I am ready to test the app J.
> > Regards,
> > *Van:*Neumann, Andreas [mailto:a.neumann at carto.net]
> > *Verzonden:* woensdag 21 september 2016 16:19
> > *Aan:* Reginald Carlier
> > *Onderwerp:* Re: [Qgis-user] QField
> > Hi Reginald,
> > Did you create pyramids in the gpkg rasters?
> > Generally, Geotiff should be well supported - definitely more tested
> > than gpkg rasters. I had a 1GB geotiff on qfield (on SD-Card) and it
> > displays fast. I haven't tested vrt files with geotiffs - if it works
> > as well?
> > Andreas
> > On 2016-09-21 15:44, Reginald Carlier wrote:
> >     Hi Erwan,
> >     You can look in the list of last week where I posted a couple of
> >     questions about qfield and was pointed to the right website for
> >     documentation.
> >     I succeeded to publish a map on my phone but the aereal photo
> >     which was published as a gpkg file doesn't render. When I use the
> >     raster.gpkg on my desktop it renders but very slow.
> >     The gpkg file was created from a 90 MB jp2 file.
> >     Regards,
> >     _______________________________________________
> >     Qgis-user mailing list
> >     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> >     List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> >     Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
