[Qgis-user] Database options
Brent Wood
pcreso at yahoo.com
Tue Sep 27 13:38:26 PDT 2016
You can use Spatialite with both - by accessing the db via odbc in LibreOffice. This is describes OS X, but should work elsewhere as well. See:
https://www.andrewheiss.com/blog/2016/02/10/libreoffice-base-sqlite-odbc-osx/
Cheers
Brent Wood
To: QGIS User List <qgis-user at lists.osgeo.org>
Sent: Wednesday, September 28, 2016 4:09 AM
Subject: [Qgis-user] Database options
Hello;I need some database options; I tried PostgreSQL, HSQL, SQLite/Spatialitem, Access (mdb/accdb) and what I get is either it works well with QGIS and doesn't work well at all with LibreBase or vice versa, with the exception of PostgeSQL which works well with both but I don't have a server to run it on. Are there any other databases that you can suggest? With no server at the moment I would like something that exists in a file in the same way; SQLite, Access, or file geodatabases do, but also compatible with QGIS and LibreBase.Thanks;Tyler
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20160927/8edf2926/attachment.html>
