[Qgis-user] Database options
    John Harrop
    jcharrop at gmail.com
    Wed Sep 28 08:01:40 PDT 2016
You could run it as a local server and it is available on all major platforms.  If you need a server with wider access you could look at AWS (even the free tier will give you some RDB service).  The Postgresql supported there has the PostGIS extension ready to load so for us it was a logical choice for hosting spatial data.
John Harrop
> On Sep 27, 2016, at 8:09 AM, Tyler Veinot <tylerkveinot at gmail.com> wrote:
> Hello;
> I need some database options; I tried PostgreSQL, HSQL, SQLite/Spatialitem, Access (mdb/accdb) and what I get is either it works well with QGIS and doesn't work well at all with LibreBase or vice versa, with the exception of PostgeSQL which works well with both but I don't have a server to run it on. Are there any other databases that you can suggest? With no server at the moment I would like something that exists in a file in the same way; SQLite, Access, or file geodatabases do, but also compatible with QGIS and LibreBase.
> Thanks;
> Tyler
> Qgis-user mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-user
