[Qgis-user] 2 Questions
Matthias Kuhn
matthias at opengis.ch
Mon Apr 3 05:03:29 PDT 2017
Hi Tyler,
Sorry, I'm having troubles to understand the question. Is this related
to QGIS or QField? What exactly do you want to do?
This mailing list here is for QGIS, if you are interested in QField, I'd
suggest to switch to one of the support channels for it, to keep the
information well-separated
(http://www.qfield.org/docs/development/index.html).
Regards
Matthias
On 4/3/17 12:57 PM, Tyler Veinot wrote:
> All;
> I found the spot for the layers, feeling a bit daft for missing that
> one. What about making a python script a push button action/tool? Is
> there away to do that or will I have to build it as a plugin?
> Tyler
> On Sun, Apr 2, 2017 at 6:49 PM, Tyler Veinot <tylerkveinot at gmail.com
> <mailto:tylerkveinot at gmail.com>> wrote:
> Thanks guys
> Sent from my Bell Sony device over Canada’s largest network.
> ---- Xan Vieiro wrote ----
> 2. Is there a way to lock features so that when I open the map in
> QField I can see those layers but cannot select or edit them? I
> want to lock my basemap features so that only my "working layers"
> are selectable and editable in QField. I partially accomplished
> this using a tool that builds the basemap into raster tiles but at
> small scales the labels interfere with each other.
> Presets works fine with QField. Located at the Layer Panel.
> 2017-03-31 13:12 GMT+02:00 Tyler Veinot <tylerkveinot at gmail.com
> <mailto:tylerkveinot at gmail.com>>:
> Hello;
> 1. Is there a tutorial on making a python script run by the
> click of a button or do I have to build it as a plugin?
> in QField I can see those layers but cannot select or edit
> them? I want to lock my basemap features so that only my
> "working layers" are selectable and editable in QField. I
> partially accomplished this using a tool that builds the
> basemap into raster tiles but at small scales the labels
> Thanks;
> Tyler
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> <https://lists.osgeo.org/mailman/listinfo/qgis-user>
> Unsubscribe:
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170403/06aa0f22/attachment.html>
