[Qgis-user] TauDEM
ALT SHN i.geografica at alt-shn.org
Tue Apr 4 11:03:56 PDT 2017
Thanks Werner,
I started by trying the standard paths, but same results. I tried those
ones assuming the space in 'Program files' could be an issue :(
One note though is that I am using QGIS from the standalone installer (LTR
2.14). Maybe I will get more sucessfull using the OSGeo4W installer.
Best,
Andre
2017-04-04 19:41 GMT+02:00 Werner Macho <werner.macho at gmail.com>:
> Hi!
> I'm using TauDEM here on an OSGEO4W installation without problems.
> But I have to say I always use the standard installation paths.
> Recently there were some problems but that is already corrected and
> should not affect you in any way.
> Probably you should just try the standard paths?
> regards
> Werner
> On 04/04/17 17:13, ALT SHN wrote:
> > Dear All,
> > I am trying to enable TauDEM provider, but so far no success. This is
> > what I have tried:
> > 1- I used the complete Full Windows Installer from
> > here http://hydrology.usu.edu/taudem/taudem5/downloads2.html
> > 2 - MPICH2/OpenMPI bin directory: D:\Microsoft_MPI\Bin
> > 3 - TauDEM command line tools folder: ~\tauDEM_64
> > Whenever I try to run a tool, the processing dialog returns:
> > '"D"' is not recognized as an internal or external command,
> > operable program or batch file.
> > Converting outputs
> > Loading resulting layers
> > The following layers were not correctly generated.
> >   * Longest Upslope Length Grid
> >   * Total Upslope Length Grid
> >   * Strahler Network Order Grid
> > You can check the log messages to find more information about the
> > execution of the algorithm
> > It looks like the Path is being taken as part of the command that is
> > launched.
> > Has anyone manage to use this provider? Any suggestions?
> > Thanks
> > *Sociedade de História Natural*
> > Departamento de Informação Geográfica
> > Polígono Industrial do Alto do Amial
> > Pav.H02 e H06
> > i.geografica at alt-shn.org <mailto:laboratorio at alt-shn.org>
> > www.shn.pt <http://www.shn.pt>
> > www.alt-shn.blogspot.com <http://www.alt-shn.blogspot.com>
> > Facebook <https://www.facebook.com/SociedadeDeHistoriaNatural?ref=hl>
> > TLM: 964138188
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Pav.H02 e H06
i.geografica at alt-shn.org <laboratorio at alt-shn.org>
www.shn.pt
TLM: 964138188
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170404/b09c3f41/attachment.html>
